Your last generator Maintenance Run
   / Your last generator Maintenance Run #6,591
You need to put a set of spinners on that… you know, pimp it up
The manual says every 100 hours, the first roughly 2500 hours I did it 100-140 hours, since then it is every 90-110 hours. Hard to be exactly 100 because it is on our food truck and we might be using it when it hits 100 hours.
Too many people just never change the oil in small engines :rolleyes:
I've never been rich enough to do that ^.
Understandable, in a food-truck application, going slightly over. On construction sites, many generators would kill for the attention yours gets.
Rgds, D.
   / Your last generator Maintenance Run #6,593
what kind of oil do you use?
engine oil that is...
Depending when I buy it, Mobile or Honda oil, usually stop at Northern Tool and get a bunch of oil at a time.
If you go with the full synthetic it is good for both the Honda and the French fry's !
No deep fryer’s, just 2 commercial smokers to smoke everything.
   / Your last generator Maintenance Run #6,594
Rgds, D.
I want (hope) it to last forever, or at least until after we sell the business.
   / Your last generator Maintenance Run #6,595
I built my nephew a generator several + years ago using a Yanmar L70 diesel from eBay which needed rebuilding. New rings, camshaft lifter & rod bearing plus seals & gaskets. A belt drive 5kw generator was purchased also along with taper-loc bushings so I could mount a pulley on the shoulder of the crankshaft which was tapered for a direct drive generator.
Belt drive was chosen because of the ability to use any motor source to run it. It also allowed us to overdrive it with the appropriate pulley to reduce engine rpm.
It was sitting in the corner of my shop since it was first built & tested & I thought it is time to pull it out & check it.
There was fuel in it so I connected the battery & it cranked & cranked🤨
Very unusual to not start within 1 or 2 revolutions.
Found the injector rack was stuck closed, fortunately.
Removed injection pump hit it with some blaster worked it until it was free then reinstalled it. Cranked it & she started up nicely.
I put 2 heaters on it for a load of 2.9kw & ran it for over an hour.
Tested engine rpm unloaded 3720rpm, 1.5kw load 3600 rpm 2.9 kw load 3530rpm. Ran excellent. I put 2oz of marine 2 stroke oil in fuel & ran another 1/2 hr.
Diesels do store well but even they need a little love to stay healthy.
A word of caution here, fortunately the rack was stuck closed (off). If it was stuck open full throttle it could have been exciting. Always need to be ready to shut the air off or fuel supply with a diesel if it hasn’t been run recently to avoid serious damage/injury.
90cummins
   / Your last generator Maintenance Run #6,596
Re: Power quality, I found this PQ1 Power Quality Sensor | Powerside
Unsure on price.
Otherwise I'd get an undervoltage relay from a manufacturer such as Phoenix Contact and set it to trigger at say 0.9x nominal voltage. Make sure to fit a squeaker so you know the fridge power needs resetting.
90cummins
Now, that ^, was a maintenance run (y)
Good point, about olde-school diesel startup practices, and thanks for taking the time to detail the build.
I was trying to frame what your builds make me think of.... then, I got it:
What You Want
, when a Carrington Event happens, during a Zombie Apocalypse !
Rgds, D.
Unsure on price.
Interesting find Patrick. Somebody saw the need, and integrated it into a small (for Industrial) footprint.
I usually prefer Simple, and not just for cost reasons. The simple solutions we've tossed around for 90's application, would mostly just need remote Temperature (and Ideally Load Power) monitoring as well. Temperature likely being the easiest to add, if not present already.
Rgds, D.
   / Your last generator Maintenance Run #6,599
90cummins
Interesting story regarding Yanmar L70, thank you!
Would you have any photos of what the engine & belt driven generator looked like?
   / Your last generator Maintenance Run #6,600
I do have photos but I have a new phone & it’s a 10mp photo which is too large & I don’t know how to reduce the file size.
2005 CHANDLER  500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
FIMCO 60 GALLON SKID MOUNT SPRAYER (A52708)
FIMCO 60 GALLON...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
Wheel Dolly (A59076)
VINTAGE SCOTT - ATWATER 5HP OUTBOARD MOTOR (A58374)
VINTAGE SCOTT -...
