Your last generator Maintenance Run
   / Your last generator Maintenance Run
Bosses asleep, more $ in your pocket...... Life is Good Fi !
Rgds, D.
   / Your last generator Maintenance Run #5,972
My first and last time that I played 9 holes of golf
my score was 75.
There is nothing that will ruin a good golf game is
that little round white thing!
When I was stationed in Corput Christi, TX I would
go out to the golf range and hit golf balls I could drive
that little white thing over 550 yards as that was the
last mark they had for the driving range and I could
drive gold balls past that sign. This guy was going to
show me how I should stand to hit the ball and I told
him why should I change my stance when I am driving
the balls over twice as far as he is?
willy
   / Your last generator Maintenance Run #5,973
Tiger Woods' longest drive on record is 498 yards. Williy, I think you are in the wrong business.
I believe most folks drive 200-300 yards. I've never hit the ball.
high winds predicted coming with next storm. Gen might just get a workout.
I started it a few days ago and it started on propane at 1003. Normal. Takes a little while to get the vapor in that carb.
I keep looking at LI batteries and inverters. Seems to be a very reliable solution.
Several TBN folks are off grid and fully self sufficient.
I bet most have at least one backup gen.
Belt and suspenders in case primary breaks.
On a 1000ah battery, how many hours of operation could I get if my draw were 30amps, say to 90 percent discharge level.
I wonder if results are linear meaning twice as long operation with two identical batteries instead of one with same draw.
While my 9500 gen will run the single central a/c unit, I would draw the line there on a do everything backup.
If I'm on backup to the backup, I can do without a/c. But not heat. With fuel oil, not a lot of load. So the priorities would be sump pump,
fridge and freezer, and then heat.
I've been thinking about a single battery with 2kw sine wave inverter, or a double 1000ah battery with a 4kw inverter. I wish there was some online calculator where
you could plug in various capacities and loads to find run time. At 30 amps and 50amp draw. I bet my offgrid friends would know.
I guess someday our maintenance discussions will only be about which smart charger we like best.
But there will always be old iron out there.
   / Your last generator Maintenance Run #5,974
Some of the u tubers that I watch are quite impressed with these units;
https://www.ecoflow.com/us
   / Your last generator Maintenance Run #5,975
Yeah, I drove the ball a little past the green on a par 4 once, probably a 400 yard drive. It was a drought year and they didn’t water the fairways. I hit the ball well and probably a 300 yard drive but it rolled forever.
   / Your last generator Maintenance Run #5,976
Lou, I couldn't find the pricing but I'd say the design and fit/finish is very impressive and
with an equally impressive price.
I think I can make this myself for less than two grand. /drew
good thing to fool around with on a rainy inside day
   / Your last generator Maintenance Run #5,977
turned out to be about 1400 dollars to build one's own, as in large 200ah LI battery, 4kw s/w inverter, 10ah smart charger, inline DC breaker, cables, etc.
And probably a platform cart to store it on and move it around on concrete if need be.
I was all set to build this when trip to dentist yesterday told me I not only broke a crown but the bridge to it also.
Almost four grand to fix. So no big projects this month for sure. Scrooge has arrived.
I like the idea of quiet power. Battery is warranted 11 years. So cost will amortize to a little over a hundred bucks a year during ten year life.
only question I have left is are the LIPO4 batteries vented and do they offgas into the surrounding air anything harmful while being charged.
Sure can't run a generator in the basement, but is it safe to do this with one big battery? I'm guessing it is. Guessing...
   / Your last generator Maintenance Run #5,978
I jinxed myself plotting....power went out half an hour ago and I'm listening to the drone of my propane portable.
and staying nicely warm
I like both formats of power delivery, but in Winter, can't see anybody complaining about noise if that means heat continues (y)
Batteries outside (shedded) with the generator, just inverter inside ?
Rgds, D.
   / Your last generator Maintenance Run #5,980
YA I filmed myself on the driving range
and look like a wood chopper LONG
ways from a golfer but I had the power
I handled freight for 2 years really built
up the muscle! To pick up 400 lbs was
noting.
willy
2008 Geringhoff NS800 8R30 Corn Head (A53485)
2008 Geringhoff...
2023 John Deere 9RX 640 Track Tractor (A53485)
2023 John Deere...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
