Your last generator Maintenance Run
   / Your last generator Maintenance Run #4,121
Very good point. I suggested to him that if it were me, I would witch the tank to Diesel and forgo the large oil sump, as long oil intervals are not a factor, if cooling was otherwise apporopriate.
There is a 400 watt oil heater, red device,, on the front. The hose is just stuck on a shaft that is sticking out.
   / Your last generator Maintenance Run #4,122
that little magnetic oil pimple heater wouldnt heat that much oil ... kinda a waste. I had one on a 1 gallon oil reserve tank....made it a little warm and ran all day in winter.
   / Your last generator Maintenance Run #4,123
I never had much luck with those, and they are quite expensive for what they are.
   / Your last generator Maintenance Run #4,124
Yes, never seen them last more than a year. One of the small standby gen assemblers here used to put them on all their air cooled units to be code compliant but they’d either burn out after a year or get the oil so hot in summer it would turn to molasses.
If you really need an oil heater, you need an immersion heater with a thermostat.
   / Your last generator Maintenance Run #4,125
Good to know. I guess adding a two dollar thermostat would double tha already high price. Always a challenge when you have an air cooled motor.
   / Your last generator Maintenance Run #4,126
relatively cool morning for once so exercising the rv's Onan/Cummins 3600 propane gen.
As always, started up after about two seconds of cranking and runs smoothly. Disconnected campground power,
turned a/c on high and cold and going to run it for about fifteen minutes to warm it up.
Gen only has 5 hours on it...and so far has never been really used.
In about six weeks I'm heading North to Bucks County PA for good, moving back to where I grew up and worked, and will rent a home there.
Will be nice to have rv so if power goes out, I can always use that for a few hours. Sure not going to spend 10k on a whole house generac on a rental home,
but might consider a home interface box/transfer switch and a 7500/9000 Honeywell or Generac. Prospective landlord is very flexible which is nice and I'd only be adding a "feature" to his rental.
generator running smoothly, only vibrates this small (25') motorhome slightly, and relatively quiet in hush box
   / Your last generator Maintenance Run #4,127
Lots of folks checking generators here in CA this week with expected rolling blackouts due to high demand from days of 100+ weather...
Sounds like a good plan d.
I think propane is an excellent fit in an RV application. Often those gens get run little or none - using a fuel with essentially zero stability issues and you have on-board already :thumbsup:.
Rgds, D.
   / Your last generator Maintenance Run #4,130
In a Home Depot this morning big pile of about 60 Dewalt-labeled 7kw generators. After last year I thought everyone in Northern California would already have a generator but guess not.
66'' root grapple (A53421)
66'' root grapple...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
(2) New 15ft Ratchet Straps (A54865)
(2) New 15ft...
