Your last generator Maintenance Run
   / Your last generator Maintenance Run
Yup. He seems to be particularly busy in Ontario these days. We had an eight hour power outage at the cottage while I was not there. Generator with an automatic transfer switch did not come on. No problem, I have a freeze alarm which is supposed to call me when the power is out, after one hour. But, the 9 V back up battery on the freeze alarm died. So why didn't it did call me earlier, saying that the battery was low? (it is supposed to do that, too.). Murphy, you rat!😡
Anyway, after eight hours the power came back on, whereupon the freeze alarm immediately called me and told me that the power was off and that the battery was down to 7 volts. (The freeze alarm left me a message on my voicemail.) So, I called the cottage, and the freeze alarm told me that the power was on but the battery was low.
To make an even longer story short, I headed up to the cottage, met up with the generator guy, and we believe that the problem was a corroded wire connection, corroded by mouse pee! A bit of scraping of the wire and some dialectric grease, and we HOPE the problem is solved, since the generator ran fine on manual run, and delivered power into the cottage no problem. We believe it was that corroded wire which is a wire for a circuit to allow the generator to talk to the transfer switch that was the problem.
A fresh 9-volt battery for the freeze alarm as well, and hopefully we are good to go. (Lots of mothballs inside the generator now as well.)
PITA, but at least nothing froze or spoiled, and I did save 8 hours of propane fuel consumption!😜
Cool story.... pun semi-intended..... I've come to see the value of just changing alkaline batteries (don't always get 'em all done though....) at 3/4 or so of life cycle on critical stuff.
As declared, I prefer to run things once in a while...... I'll now add mouse pee to the reasons why ! Murphy has many allies, large and small :shocked: .
I remember once on a bike (MC) forum, a guy described his repair on what should have been a fairly mint-condition carburator..... turns out that a tiny ant had somehow crawled into the carb and expired in a critical spot. Once he was done with the blue-air words, he did comment that it was actually impressive how such an tiny thing had stopped a relatively massive machine.
Rgds, D.
   / Your last generator Maintenance Run #982
Those heaters you use grs sound like the cat's pajamas ! :thumbsup:
Reminded me of something Honda markets here on their generators.... managed to find a description just now....
Cold Climate Technology
Honda's industry leading "Cold Climate Technology" is specifically designed for our cold Canadian winters. Our exclusive breather heater system helps keep the crankcase ventilation tube free of ice formation and helps prevent generator shutdown.
That paragraph is buried down in the Why Buy a Honda section (in Read More):
Honda Canada
I'm curious as to what extent that feature is available in other geographies.
Rgds, D.
Generac also has a Air cooled breather heater, but only recommends its use in severe cold areas. im not using one of those.Generac model 7103. 7103.jpg
   / Your last generator Maintenance Run #983
would one of those heaters have prevented what Dave and I both think is ice/water ingestion? It was below freezing and icy when this happened.
   / Your last generator Maintenance Run #984
My 22kw Generac went on test cycle right in the middle of last weekends cold temps and ice.
Not a happy startup at all. Surging, sounded like rpms rising, kind of a misfire, then after fifteen seconds, smooth as could be. Did I ingest some water/condensation/ice? Propane, 500 gal tank, full.
Not sure how much computer you have on your generator if any but most gas engine call for more fuel when cold and will backfire and hunt for fuel when lean. Also most on demand propane regulators are vacuum operated and when you start your engine and the governor pulls the throttle plate wide open in the carb it does not have as much vacuum. Most of my engines are on propane and they seem to need the spark plug changed more often . Propane is 110 octane and burns slower then gasoline and usually needs the timing retarded slightly (which I never do ) The way I understand it is it has a longer fuse and needs lit quicker to ignite at the same time gasoline would. With a 500 gallon tank you will never have a problem with it not vaporizing fast enough, I use 20 pound cylinders on 4 cylinder engines and only have problems at wide open on some days, nothing two 20 pound tanks would not fix.
Interesting point about the plugs - not what I would have expected. Then again, air cooled generators are tougher on plugs in general than most automotive applications.
Years ago when propane was more of an option on vehicles here, cold-start (re. vapourization) on those older systems below -30C was often an issue, but I suspect daugen wasn't near those temperatures.
Good point on the vacuum aspect. With propane my guess is there is less of a chance of the fuel being directly contaminated with water, but that is only a guess. I know my MC has a vacuum operated fuel petcock, I wonder if daugen's auto-gen is similar. My bike takes extra cranking after sitting all Winter, to prime the fuel line..... really need to move a MityVac up my Tools to Buy list....
Rgds, D.
IMO they'll help, but not guarantee perfection. The ones grs uses I can see being a good aid for cranking over in cold - battery is warm therefore higher capacity, and oil is pre-warmed a bit.
IF
our guess is correct, and you had a tiny ice crystal sitting where it shouldn't have been, that is pretty tough to defend against 100%. The other breather heater grs listed is for really cold operation - my guess is what happens in extended runs in very cold ambient is the breather tube may build up crystals and block up.
Likely not practical to do on auto-start systems, but a good point has been made here recently about leaving manual chokes On when stored. Weird combinations of moisture and temperature swings can deposit condensed ice crystals in strange places (like the trunk of a car I had parked at an airport recently), closing the choke for storage on manual units might help a bit.
Rgds, D.
   / Your last generator Maintenance Run #988
Rgds, D.
I am sure there is a vacuum port on his regulator that runs a hose to a port on the engine side of the throttle plate in the carb, it is a safety device to shut off the propane if the motor quits for any reason. My floor burnisher has two of them.The regulators are so sensitive that they have to be mounted vertical so the weight of the diaphragm does not affect it in a lean or rich way, just about the only rule in mounting them other then the closer to the carb the better .On my mowers I have to put the throttle in the lowest idle position to build vacuum to start, on the burnisher I remove the vacuum hose and put it in my mouth and draw on it till it starts then quickly put it back on the manifold.
   / Your last generator Maintenance Run #989
You guys with residential auto start generators. Is your switch gears not able to load your generator during test runs?
The 80KW diesel generator at the chicken coops gets test loaded every week. Switch gear starts generator, lets it come up to speed and transfers, placing load on generator for about 15 minutes, then a 15 minute cool down before it shuts down generator. The switch is fast enough that the lights don't even blink unless I'm close to max draw. The computers/alarm system don't even register the switch.
But it got a 2 hour exercise Thursday night when the line fell in the neighbors woods. At 10pm. Load around 50 amps. Little birds+cold weather=light load.
   / Your last generator Maintenance Run #990
My 20 kw, Aurora uses a Milbank Vigilant ATS and everything stays on when it transfers during the monthly test or manually testing.
199049 (A51243)
199049 (A51243)
Kubota ZG327 (A50120)
Golf Cart (A55853)
Golf Cart (A55853)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56129)
2018 FREIGHTLINER...
Portable Restroom (A54865)
Portable Restroom...
2016 JOHN DEERE 323E SKID STEER (A52707)
2016 JOHN DEERE...
