Your last generator Maintenance Run
   / Your last generator Maintenance Run #1,001
I run the carb empty on my genny every time I shut it down. I find that if when I want to fire it up, I turn on the gas, then check the oil, choke it and pull it over one or two times half heartedly (never expecting it to start) then hit the Electric start. She fires right up.
this is how I kill mine too. I never use the kill switch. Just turn the fuel on and then turn it off to shut it down. I got this one from my father in law. He would always leave fuel in it and I did as well the first few years I got it. It always had crystals in the carb and would not run or shut down when I needed it. That's when I started shutting off the fuel to it . It needed a carb rebuild as it was always hard to start but it was in an outage so I never did anything. I have to run half choke to run well. But years later I still have not built the carb and its easy to start now so I have left it be! Just keep the choke part way on.
I think it backfired one day it was very hard to pull over, like it had super compression. ANd would not start. I pulled the valve cover and discovered that one of the rocker arms was off and push rod bent. I put the rocker back on and ran it like that a few times. The next time I tried to straighten it and that worked for hours, till I ordered the correct push rod and finally tore back into it to replace it. I bought the rocker too but it somehow was wrong? I had the parts for like a year or more, guess I looked up the wrong parts diagram and the rod just happened to be the same but rocker wasn't? Oh well a few dozen hours and all is still good, thank the lord.
I did notice this time the starter rope is getting frayed where it hits he recoil, I need to replace that before I pull it off one day when I need to use it.
Was there a reason people move away from the propane on the cars there in Canada, Propane prices? They are back to putting it on school buses and county gas powered pickups here. Public transportation is 100% Natural Gas . The Dairy north of me run there Semi tankers on methane gas from there own Digestor . The Interstate I65 has natural gas fueling station spaced out . We have gotten so many wind turbines in the last 10 years I doubt any body knows how many are here now, natural gas prices had to come down to compete with them to generate electricity.
20 to 30 years ago, we had govt tax incentives to convert cars/trucks to propane. Biggest problem here now is lack of distribution - auto propane (distinct from bbq refill) is not easy to find, public NatGas even harder. Haven't seen them myself, but have read about recent build-out along the 401 corridor and into Quebec to support commercial traffic. Natgas is big in commercial fleets here, but they have access to private refill stations.... the trucking industry keeps asking the govt if they'll keep their tax claws off the Natgas as they convert more trucks....... of course all you hear from the govt is..... crickets.....
The only catch to propane was low temperature - looks like the boiling point is about -42C..... older vehicle systems sometimes had issues starting in the dead of Winter.
I'd like to see a lot more public auto propane and natgas refill stations here... buddy 'o mine much prefers to run his Natgas F150 in the BC lower mainland, but that is also a function of BeSea's insane gasoline prices....
It's nice to be able to shop around for fuel alternatives.
Rgds, D.
That was a good bit of luck with the pushrods.... what engine brand is that clemson ?
Rgds, D.
   / Your last generator Maintenance Run #1,004
I drove a couple of propane vehicles. Both Ex-police. The first a converted 82 Malibu didn't stand a chance starting in extreme cold. The second, an OEM 87 Dodge Caravelle, never gave me any starting issues.
I actually have had more anxiety finding Diesel late at night then I ever had finding propane. Maybe, I just planned better, back then.
   / Your last generator Maintenance Run #1,005
Double post
I'd expect a modern propane design to perform well in Winter. Not that I can afford to hire Jack to do a gen conversion for me, but here's what Roush is up to these days for Ford:
Fuel System Overview - ROUSH CleanTech
Rgds, D.
   / Your last generator Maintenance Run #1,007
Rgds, D.
lot of specialty parts in there but none should be crazy expensive other than that fuel rail. Would it be considered "common rail".
Seems to be handling liquid propane much like gas. And now a major bus manufacturer has spec'd it for their small school bus.
Our Products - ROUSH CleanTech
what this tells me is that tech on larger gens might become more sophisticated in the future, the ones using car engines.
   / Your last generator Maintenance Run #1,008
Thanks for the link. I do not even know about the Ford F-59 stripped chassis but did know about the F-53 that is common for gas motorhome chassis. Sounds like liquid propane technology has really progressed.
   / Your last generator Maintenance Run #1,009
Rgds, D.
It is a 10 HP Briggs. Its about 15 years old or so. The strange thing is that I looked up the parts from the engine model number on the engine so I am not sure how the rocker could be wrong?? Maybe I typed the wrong number into the search when I typed it and it was one number off or something on the rocker? Who knows at this point I don't even know where I bought them from. I think the root of the problem might have been wear and or backfire, valve adjustment which caused the push rod to be slightly out of place and get bent or something. I am just glad its working and been working fine. Before I replaced the push rod it would throw it every few hours of use. You could tell cause it would abruptly stop and would have like super compression letting me know the rocker was off.
Thanks - have an old Briggs myself, and was curious about the pushrods interchanging.
Rgds, D.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Takeuchi TL250 Skid Steer (A54865)
Takeuchi TL250...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
SHELVES W/CONTENTS (A55745)
SHELVES W/CONTENTS...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
Portable Restroom (A54865)
Portable Restroom...
