Your last generator Maintenance Run
   / Your last generator Maintenance Run #6,761
I think building a new gas station is no longer allowed here.
Many street corners I remember having stations are empty lots now.
I would not be surprised if only a third of the stations from growing up around here still exist…
We still have them going in, here. Mostly driven by convenience store chains (eg. Wawa).
I've been told that, at least locally, gas stations don't make much at all on fuel sales. The profit is in the associated convenience store. This might explain why you see relatively few new fuel-only stations, these days.
The only fuel-only station I've seen built here in the last 10 years is associated with a local car and truck dealership group. They probably save enough on fueling their own vehicles, and heavy trucks, to cover the new construction cost.
   / Your last generator Maintenance Run #6,762
Ya, when i bought my Jimna 6 chipper, the sales guy warned me i should drain the drive oil and replace rubber seals and hydraulic oil. The included oil looked like water. But that unit is about 12-14 years old… just keeps on going. Today i had to tear it apart to do 2 welds and reverse the knives and adjust anvil. Theres 3 hours of my life ill never get back. But its chipping like new again. But the owners manual says set knife gap around 0.030” or thickness of a dime. Last time i used a dime to set it. This time i got to thinking…whats the true thickness of a dime…. 0.075. No wonder the chipping wasnt like it used to be. After resetting it to 0.030 its working great.
stinking Chinese to american instructions….. 20240527_130812.jpeg 20240527_130753.jpeg
   / Your last generator Maintenance Run #6,763
My solution to the lousy fuels is to use Avgas. It can sit for years with no degradation, mixes well with 2cycle oil. I’ve been using it for decades with no issues.
However, its future is bleak due to environmental pressures.
Also I understand that not everyone has easy access to it.
But if you can get it, I’d recommend using it in all your small or seasonally used engines.
I was hoping for better news than, Our Transport Networks rely on over-priced junk food to stay operating !
:cool:( Same story here, for a long time....)
Rgds, D.
stinking Chinese to american instructions…..View attachment 872431 View attachment 872432
Good story, and chuckle.
One of my fav ChinGlish translations came from instructions a buddy received: Light Switch referenced as Dark On, Dark Off. I kind of like that one, actually.....
This thread has been running long enough, this next could be my third re-post.....
Bi-directional (spoken) language translation software, years ago. Standard validation, loop a phrase out, then back through. English "Out of Sight, Out of Mind" went to Russian, then Russian back to English.
Final result was "Blind, and Crazy". I used to like that result somewhat, but today, reminds me too much of where I work.....
Rgds, D.
Last I heard (not a flyer, so am not dialed into current 411), carb icing was the concern re. moving away from LL.
If I knew somebody local that flies, I'd stop by the little regional airport north of me and see if I can buy LL To Go. Probably are regs to discourage this, so if I drop by on my own, I wouldn't sell to a potential inspector either, if I worked there.....
Rgds, D.
   / Your last generator Maintenance Run #6,767
Av gas is way, way more expensive than ethanol free, but if you live in an area without ethanol free….its a way to go.
   / Your last generator Maintenance Run #6,768
I cannot recall having gasoline related issues with any of my equipment. I been using stabil for 10+ years but never used it in my chain saws & I’ve always been impressed how they’ve always started.
I’ve always thought the two stroke oil played a part in this acting as a stabilizer.
I bought a gallon of Pennzoil two stroke marine oil last year to start dosing my fuel in the fall.
It definitely makes a difference in my 1990 Dodge Cummins noticeably quieter.
90cummins
   / Your last generator Maintenance Run #6,769
I believe it does. It's been awhile since I've actually sat and read the label of any 2-stroke oil bottle, but I recall they all used to say "with fuel stabilizer" on them, 20 years ago.
   / Your last generator Maintenance Run #6,770
shelf life on additives always made me wonder.
when does the stuff that keeps your gas from going stale go stale itself?
industry should do better job of labeling "use by" dates clearly.
I have a gallon can of the expensive non ethanol premium gas bought off the shelf at TSC three years ago.
as long as it doesn't smell bad, I need to dump that in riding mower. I keep forgetting...
I also have a five gallon real gerry can of premium gas I need to put in motorhome along with a couple cans of Sea Foam.
And then refill that can with fresh.
it's kind of a disaster can. Hope to never use it. Would be up the creek if that happened, because I would have already burned through
4 30 pound propane bottles for generator.
just need to remember to rotate my storage gasoline. Propane is very low maintenance in comparison.
All a matter of where power is still on, will Tractor Supply have a generator onsite that allows their propane tank to keep filling mine up?
I should ask next time, or look around for the gen.
I can cross the state line within minutes and be in NJ where another power grid will power the gas pumps over there.
So gasoline is always a backup, but at least it's likely to be there.
15 gallons of gasoline and about 40 gallons of propane when I'm full up.(7 gal per 30#)
that's a nice combo for disaster in a fire...
And yes as an ex volunteer fireman and insurance agent I have placards in my detached garage showing gasoline and Propane storage warnings.
I would not want my garage to fire up even with the fire company substation three blocks away.
I'm about to have a large utility shed added behind my garage and want to get all this flammable stuff out of the garage
which reminds me of an inspection I did for a new homeowner policy 40 years ago on one larger local property, and when I opened the utility shed, my
heart almost stopped. Two big cans of HTH Chlorine for their pool, and three cans of mower gas piled near the chlorine.
And an open window nearby that allowed rain to come in. Oh my, oh my, oh my. Chlorine got moved immediately.
any petroleum product will make chlorine basically explode, we used to demo that on annual fire company night out.
Lot of swimming pools around here, lot of chlorine. Safe storage is seriously important, good ventilation,etc.
simple fact folks do not respect the power of chlorine or gasoline. For sure, keep them far apart.
(4) Motreal ST2051/7515 Tires (A57149)
(4) Motreal...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
LOT: Fuel Transfer Tank, Tool Box (NO PUMP) (A59076)
LOT: Fuel Transfer...
2014 Toro Z-Master 5000 Series 72in Zero-Turn Commercial Mower (A56857)
2014 Toro Z-Master...
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
