Your last generator Maintenance Run
   / Your last generator Maintenance Run #6,061
I just changed my oil yesterday in my little 20kw Cummins genny (actually an Onan diesel). It's my first oil change and I was surprised it took 6 .....quarts! 😆
Sounds like d is in the market for an upgrade ! :cool:
That's what scares me on the small portable stuff.... many barely hold One quart/litre.....
Rgds, D.
   / Your last generator Maintenance Run #6,063
something tells me this EMD would not pass California emissions.
Maybe not, but it sure would sound cool when you fired it up!
Back in the 70s, we put in pads for Miles Laboratories in Elkhart, IN so they could install three EMD gensets. They were all 16V645E3 2MW units, and they were impressive when they were running. They were skid mounted and weighed about 50,000# each.
   / Your last generator Maintenance Run #6,064
I didn’t expect these results!
After what seems like an eternity I’ve finally programed the Conext AGS (automatic generator start) so it’s operational.
Without exaggeration I have spent hundreds of hours looking for information to understand this poorly documented system.
Before I go any further I will explain my system as a refresher.
I built a building (power house) for my 2 generators. The generator currently operating and automated is a home built unit with a Yanmar L100 diesel belt driving a Niehoff N1603 450 amp 28 volt DC generator.
Power is delivered to my four L16 deep cycle batteries which are connected to my 4kw inverter.
The engine is set to run at 2700 rpm which is the sweet spot for this engine determined using the Yanmar spec sheet and fuel consumption chart, the generator is turning 1400 rpm.
Earlier this week I finally decided it was time put my generator into auto start mode and see if it would operate as planned. I started it manually first to warm it up because it does not have a cold start aid yet then I shut it down and placed it in auto mode and let it start/stop automatically for 4.5 hours powering the entire house.
The engine started when the battery voltage dropped to 24.4 volts and shut down when the voltage reached 28.1 volts.
The hot air wood furnace was operating with a ¼ hp motor driving a squirrel cage blower.
We went about our normal business with the deep well pump operating when needed, being on the battery backup we treated it as an outage to conserve power but the entire house was powered and we carried on normally.
For measuring fuel consumption I use a postal scale that measures grams weight.
1 gallon of diesel weights 3218 grams.
The test was 4hrs 36 minutes = 276 minutes duration.
The engine ran 122 minutes total.
Fuel consumed was 1280 grams which is 2.822 lbs which is less than 1/2 gallon.
Using the above figures the system will provide 11.5 hours of power maintaining heat, lights & entertainment per gallon of diesel.
This is more efficient & capable than my Honda EU2000 which can run 10 hours at low load but is not capable of powering my well pump.
Definitely proves a Hybrid inverter system using efficient diesels, DC generators & batteries works.
My system uses 4 L16 deep cycle batteries which are past their prime which resulted in several starts of the engine, the number of starts is unknown.
I believe a larger battery bank would result in fewer starts & I would suspect the efficiency could be better.
That's my latest update
90cummins
90cummins
Congratulations 90, you've put a ton of work into that system, great to see these results.
Efficiency is impressive, but I also really like that this type of hybrid marriage gets one away from the problem of constantly running a diesel to only support very light loads (y)
Excellent news !
Rgds, D.
   / Your last generator Maintenance Run #6,067
Snip
Snip
90cummins
Nice data there, You can probably lengthen your cycle time significantly by increasing your cutoff voltage a bit.
I wouldn't be worried by making the shutoff voltage as high as 29 or even 30 volts, especially in colder weather.
Given that lead acid batteries don't charge that much until they reach higher terminal voltages, the amount of energy they absorb rapidly slows down as they charge up.
If you do push them higher, it's very unlikely to hurt them as you're not charging them to a high terminal voltage for any appreciable amount of time and your loads will start discharging them immediately.
   / Your last generator Maintenance Run #6,068
also note if your not doing a equalize charge on lead acid, you are slowly killing them to sulfation.
I would be interested to know how the honda would rank, if given an ac charger to charge the battery bank and perform the same test.
   / Your last generator Maintenance Run #6,069
With the price of gas compared to diesel, the Honda would still be cheaper to run. At least where I live.
SR
   / Your last generator Maintenance Run #6,070
What's the model number of your inverter again 90? I have two ideas :)
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
2007 JLG 41AM DC Electric Vertical Mast Lift (A50322)
2007 JLG 41AM DC...
2025 REDELIFT CPD25-XD4 FORKLIFT (A52141)
2025 REDELIFT...
Hay Forks (A50515)
Hay Forks (A50515)
Barn Wood Picnic Table (A50515)
Barn Wood Picnic...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
