Your last generator Maintenance Run
   / Your last generator Maintenance Run
Ok, just kidding. Have a nice electric exhaust fan on the other end that plugs in to the generator, plus the side walls don’t go all the way up. That should be enough.
10-4...... just being nosy :).... thanks.......
Rgds, D.
   / Your last generator Maintenance Run #5,002
I'd say buy a lottery ticket Gale, but you've already used up quite a bit of luck with that save :thumbsup:
Nice feeling for sure, having that coming back to life with that mess in the forecast. Heavy ice will end up taking lines down, but 15" of snow is a bit of work, esp. if your area doesn't deal with much normally.
Stay safe, and esp. on the roads.....
Rgds, D.
Yes I got very lucky. I can't complain about that 30 year old 18HP B&S engine that's had little attention.
Thankful the ice is staying south of us . We will see how much snow we get Wednesday and Thursday on top of our 2 inches.
knowing the generator is ready to fire up on a moment's notice is a good feeling.
Old school ones (some of their newer designs were updated in this respect, IIRC.....) like your Briggs, and mine, are loud in stock configuration, but I've found the reliability to be good. Had one stuck float on one of mine, but that's a fuel issue, not a Briggs issue.....
The one Briggs I have that's likely got enough hours on it qualify for a valve check is in my push-mower, but as it's still producing good power, I haven't found a RoundTuIt for that task yet.... Especially with push-mowers, I find many people (including some who definitely know better) never/ever even change the oil..... at least mine has had that done :).
Rgds, D.
   / Your last generator Maintenance Run #5,004
Thanks to the ice the 22kw got a 26 hour workout.
Everything worked properly during the outage, but did end up with one equipment casualty, a 12-15 year old 1200VA tripplite UPS died after the stop/start at 24 hours to check the genny's oil (battery was still good & fully charged, the UPS just cut off & wouldn't go back on-line).
Out of curiosity, did it burn any oil? Is it a 3600rpm air cooled, like the Generac?
If the battery in your UPS is the original, it could be the source of your problem.
   / Your last generator Maintenance Run #5,005
My 22 KW went thru 2.5 days of usage...more or less. Checked every morning. Used no oil according to dipstick.
   / Your last generator Maintenance Run #5,006
No oil use & still clear as when it came out of the bottle. The UPS battery was still fully charged & swapping in a spare I had on hand made no difference. I've probably changed batteries in that unit 4 or 5 times over the years.
   / Your last generator Maintenance Run #5,007
No oil use & still clear as when it came out of the bottle. It is an air cooled Honeywell, so pretty much identical to Generac (same factory?). It was installed by the local Generac dealer via Costco.The UPS battery was still fully charged & swapping in a spare I had on hand made no difference. I've probably changed batteries in that unit 4 or 5 times over the years.
   / Your last generator Maintenance Run #5,008
I know the TrippLites at work are very sensitive to dead batteries, they will not turn on with a dead battery.
Aaron Z
   / Your last generator Maintenance Run #5,009
Yes the Honeywell units are just rebranded Generac.
Thanks for the reply.
   / Your last generator Maintenance Run #5,010
Yup, and I always thought it was funny when a customer demanded a honeywell, and not a generac unit
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
