Your last generator Maintenance Run
   / Your last generator Maintenance Run #4,201
Yep... I have reduced peak demand cost a little by staggering equipment start times...
Once upon a time everything started at 5 am and the load reflected it.
   / Your last generator Maintenance Run #4,202
Optional gen fire, instead of stringing ext cords, I find is a great way to motivate myself to get a run in..... :thumbsup:
'ol Murph never sleeps, so it's hard to be too pro-active.....
Rgds, D.
Yep. See a couple areas on the fence that did not get as clean as I would like. So may fire things back up this weekend to touch up. The power washer really does not like extension cords anyway, it draws a good bit of power.
Next up is an oil and fuel filter change. Spark plug was changed in the fall as it had fouled up.
   / Your last generator Maintenance Run #4,204
I also just got done scrubbing about 800 feet of 3 rail vinyl fence, but i use a gas power washer, vinyl fence cleaning solution and rags.... and lots of boring time. Have about 670 feet left to go
   / Your last generator Maintenance Run #4,205
Yup definitely a good plan. Here’s my backup to my propane powered standby.
   / Your last generator Maintenance Run #4,206
I chuckled when I opened an email from a lifelong friend who has moved to Tampa area. I guess he got tired of losing power in hurricanes and finally decided
to buy a generator. I told him great choice, it was the exact model I will buy once I move to PA, and then I gave him links to the exterior 50 amp outlet and the transfer box.
Learn a lot here :thumbsup:
I told him to put a battery charger on battery twice a year(or a maintainer) and to only use non ethanol gas in it.
Amazon.com : Westinghouse WGen75 Portable Generator with Remote Electric Start - 75 Rated Watts & 95 Peak Watts - Gas Powered - CARB Compliant - Transfer Switch Ready : Garden & Outdoor
actually I intend to get the next larger model which puts a full 50amp out in one cord.
Lots of features at what I could see on Amazon for a price-point d.
Remote start is convenient.... guess those carbs are onboard RV gen style. Not sure about the larger one, but that 7500 has a dual-fuel model option.
"Bench-racing" a next portable generator, I somewhat lean towards either gasoline/propane, or fuel injected. Not remote-start out of the box, but this Generac seems to be a nice combination of FI and wattage (vs. $).....
Generac Power Systems - Best Portable and Inverter Generators
Looks like they are putting CO detectors on 'em too.... A lot of the fun is in the looking :)
Rgds, D.
   / Your last generator Maintenance Run #4,208
Lost power during wind storm about 20 minutes ago. Was making breakfast. Nice to be back cooking 15 seconds later.F02CCA05-9C7A-4F9E-A251-3122825875A4.png. Man is it windy out there . Blowing dust obscuring everything.
Lost power during wind storm about 20 minutes ago. Was making breakfast. Nice to be back cooking 15 seconds later.View attachment 668945. Man is it windy out there . Blowing dust obscuring everything.
All back, running in the green-zone. Nice.
Rgds, D.
   / Your last generator Maintenance Run #4,210
Out coop web site lists 11,900 residents without power
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
Truck Absorptions Attenuator (A54865)
Truck Absorptions...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
