Your last generator Maintenance Run
   / Your last generator Maintenance Run #2,731
Wouldn’t you know, I just finished installing the generator I repaired from a lightning strike on my neighbors house, and we had a huge wind, lightning and rain storm come thru. I thought we’d get a good test of the System, but no power was lost. Goes to show you that once you install a backup system..... you never lose power.
I think you've been 10 for 10 on that No Lost Power-Line Events with quite a few of these customers grs !
Rgds, D.
   / Your last generator Maintenance Run #2,733
Rgds, D.
yup. But this storm came in same day I finished job.
   / Your last generator Maintenance Run #2,734
After I typed that, I was thinking "pressure is easier to come by (for most backyard wrenches) than vacuum, but this is really a vac deal". I can see that vac pump + meter is the way to go...... pressure + soapy water is easier/cheaper for me on other things that I don't do for a living, or often.
Devil in The Details..... a lot of guys skate along ignoring application specs, but your point about gate valves is a good example of the major headaches you can create doing that..... I learned that lesson years ago, ignoring an installation requirement on a Bosch electrical part, that didn't initially make any sense to me.
Rgds, D.
It’s actually easy. Mityvac pump and a little clear line. Look for the bubbles and loss of vacuum.
Saved customers literally tens of thousands of dollars this way. Often only involved after they’ve spent the money and end up calling another company though.
It痴 actually easy. Mityvac pump and a little clear line. Look for the bubbles and loss of vacuum.
Saved customers literally tens of thousands of dollars this way. Often only involved after they致e spent the money and end up calling another company though.
Simplify..... Simplify..... like it ! (Pro-wrench buddy reminds me once in a while "You're over-thinking this". :)).
Despite all the modern sensors/controls, start with Fuel, Air........ I can see all sorts of parts getting swapped, just for the air leaks you describe.
When you posted about those leaks, I was thinking "Run a temporary one-piece test line" (bypass existing line).... but that requires stepping back from the "parts problem" to get the same perspective.
Rgds, D.
   / Your last generator Maintenance Run #2,736
Ive run temporary lines several times to prove the issue. I’ve also had to do that to convince engineers that their pipe routing was contributing to the problems. Engineers and contractors will both tell you it can’t be an issue they’ve been doing it (wrong) that way for 30 years. Usually the issues show up after several years when they are out of the picture. Brand new gate valves will usually seal well enough the small amount of leakage isn’t noticed at first.
I guess I should’ve just put everything in the first post I guess...
You also need to avoid any elevated horizontal runs as they collect air over time and can never be fully bled - think of it like a sewer pipe with the liquid running along the bottom. There is always a small amount of air in the fuel from filling the tanks, return fuel splashing etc and when there is a surge of flow when starting or load application some of that air gets carried into the engine.
Also applies to liquid propane lines but even more important if they are in the sun. The heat of the sun will vaporize some of the LPG in the line and it will collect in the high spot but can never condense back to liquid in the lines. When it hits the liquid regulator it wont open the reg and blocks the liquid fuel.
Stop by for a brief chat, get hit with lots of pesky questions - for free ! :D
Better with sloped horizontal lines to deal with those factors (direction ?), or do you need to implement other measures to deal with those air or vapour problems ?
Rgds, D.
   / Your last generator Maintenance Run #2,738
Sloping the line just moves the problem to one end. That works for keeping liquid from pooling in a line like a crankcase breather though... If you run the crank vent out of an enclosure be sure to keep a constant slope so it can’t pool, block the flow and pressurize the engine. If you slope it up and use black iron pipe it will condense a lot of the oil vapour and return it to the engine so you use less oil. Not a good idea on a Nat gas or propane engine since you are also trying to purge a large amount water vapour through the crank vent.
The proper solution is running fuel lines on the ground and keeping the elevated horizontal section out of the top of the tank as short as possible.
   / Your last generator Maintenance Run #2,739
I knew the name Monel, but had to look up the composition. A few traces of other things, but it's mostly nickel and copper - like my favourite brake line material NiCopp.
On-water, with less than a full tank much of the time, and probably a low rate of consumption...... I could see that getting messy after not that many years.
I think that's part of why diesel is not such a good fit for many N. American consumers..... needs a bit more of a maintenance program than gasoline.
Boat application like that...... regular prophylactic use of biocide might have helped, esp. now with ULSD.
Rgds, D.
I came across Monel .625 dia. rods for next to nothing at a plant auction... made a lot of "Lifetime" Model A Ford water pump shafts with it...
Original shafts are plain steel... OK when in use but not so good when a car might sit unused for most of the year.
   / Your last generator Maintenance Run #2,740
Today was my monthly test day. Ran it for an hour with a 42 amp load. All good!
New/Unused CFG Industrial KKT(A)27 Mini Skid Steer (A54865)
New/Unused CFG...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
New/Unused Quick Attach Pallet Forks (A54865)
New/Unused Quick...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
