You need balast or you will trash your front axle!!!! really?
   / You need balast or you will trash your front axle!!!! really? #131
Obviously this is a very conscientious operator, thinking to fully protect his font axle in this way. ;)
That is what split brakes are for. 😟
   / You need balast or you will trash your front axle!!!! really? #132
Anybody ever break a rear axle from too much counterweight?
   / You need balast or you will trash your front axle!!!! really? #133
The limiter is how much you can lift, that I have seen is tractors break i half with heavy load on front and rear combined with high speed on the road, combined with a speed dump and a brutal driver it goes badly.
My cousins JD4300 would break in half every ~1000 hours of use. He used it exclusively for back hoe work and to move pallets of rock that it could only lift a few inches off the ground. That tractor was never designed for that type of commercial use. However, it did have a good front axle. Never a problem with that.
I would think replacing a front axle would be a whole lot cheaper than fixing a tractor that broke in half!
I suspect different tractors have different weak points. As such, any general guidance to maximize longevity of a given model's various parts needs to be taken for what it is - general guidance.
In addition, with the limited number of failures as examples for specific models, it seems it would be nearly impossible to piece together supporting data to construct the best ballast plan for a person's tractor given that person's specific uses.
However, with ROPS on modern tractors, it is easy enough to tie the top of the ROPS to the loader frame via a FOPS/cage and help manage stress in the middle of the tractor from heavy weights on both ends. Since I've already taken this step, I suppose a counter weight on the 3pt is in order. Which means a quick hitch of some type is in order. Because without a quick hitch I'll never use it!
Proper counter weighting will allow you to break your loader frame before your front axle ever gives up, and that probably only happens if "bulldozing" where you can apply more force to the loader than it was designed for.
Hmmm... which costs more to fix? I think I'd rather break the loader. A local welding shop should be able to fix that fairly easily and cheaply.
   / You need balast or you will trash your front axle!!!! really? #136
You must never have been on a teeter-totter. You couldn't possible think the way you do if you had. A tractor with FEL and rear ballast (behind the rear wheel) will act the same way. Just because the wheels are all on the ground, it doesn't mean that they continue to have the same force exerted on them as weight is added at either end. I have seen my fathers old 8N with all four tires on the ground but with such light force that turning the steering wheel had no effect on turning the tractor. By your thoughts, as long as all 4 wheels are on the ground adding weight to either end has no effect. You can put enough weight on either end that the tires are on the ground, but a 6 year old could lift the light end off the ground.
I just find it hard to believe that folks cant understand simple weight and balance problems when it comes to tractors.
Well not to hammer on Axle hub but- has gone around with some other posters on this issue before- including me.
He was able to dismount his tractor, (FEL loaded) and have a rear tire loose contact with the ground in an earlier thread-
but at that time apparently did not think adding substantial weight to the 3 point would be of much benefit...
Hope it has been made much clearer - some weight added to or behind the 3 point most certainly helps when hauling a lot of weight in the FELs bucket
And has a lot to do with safe tractor operation.
This has been made clear with posts on this and other threads.
Thought this and many previous threads settled it -but in the future will see another thread, or some will keep disputing well Known facts...
my:2cents:
ps
after reading the above posts (The other side of the coin) I admit adding weight to the rear of the tractor and heavy fel loading while roughly operating the machine has led to breaking a machine or two in half. Finding a happy medium with safe operation is what everyone shoots for.
   / You need balast or you will trash your front axle!!!! really? #137
Not calling anyone out because I have valued and enjoyed all of this discussion, but I do encourage some thought on this if you are still struggling. I noticed something here that a few folks are missing and it is critical.
When one loads a loader, or forks, or a grapple - that weight/force is not being placed directly in front of the axle like in the case of a snow plow on a truck. The loader connection points to the tractor are typically located closer to the operator station and thus the forces are distributed to both the rear and front axles through the tractor frame. It is the distance to fulcrum where the force acts that is important here. One can still load the bucket sufficiently to "unload" the unweighted rear, but point is you are not placing and distributing the force directly at and beyond the front of the front axle.
This concept allows fun center of gravity toys like this to function.
So - adding 1,000 pounds on your 3pt can easily and fully counter balance a full 1,000+ pounds in your loader due to where the forces are actually acting. In this case your loader force is always acting behind your front axle, and if the load is extended far enough forward, or heavy enough to push the center of gravity past the front axle, then it will tip up. (That would be the case where someone pushed down on the eagles wings and your finger is the center of gravity/front axle).
That tipping forward will never happen if you have proper counter balance beyond the rear axle, AND your operating front axle loads will be at or below a fully unloaded tractor scenario. Having counterweights protrude past the rear wheels is a little bit of a pain for agility, but placing just 500-1,000+ pounds a good distance outward of the rear axle will let you do wheelies all day with a completely full loader and a football team hanging off the loader. This is why I sometimes use a heavy duty cutter for counter weight as it places some of the weight at a greater distance and provides a greater force/moment acting on the rear axle fulcrum which in turn helps reduce the loading on the front axle in all circumstances.
To help with the wheels on ground vs lifted issue, think about the split second before your rear wheels lift off the ground. At the point, all four tires are still in contact and yet the force on your front axle is almost at its maximum stress. If you placed your pinkie finger on the loader bucket and pressed down, then the rear wheels would lift off the ground. The difference in force on front axle in those two scenarios is negligible. The force progression is continuous and nothing special happens when the rear wheels finally come off the ground. The force on the rear axle simply goes from one pound to zero pounds...
Conclusions:
1) Counter balance weight at almost any distance behind the rear axle can and will offset similar weights/forces added to the frame of the tractor and thereby front axle when using a loader. More weight, and or greater distance from the rear axle will amplify the effects of lightening the front axle load. The impacts are far greater than just a nominal 10% or so mentioned earlier since the loader is imparting its forces towards the middle of the tractor which is not too terribly much farther from the rear axle than are the ends of your three point hitch and added counter weights. (Box Blade, Cutter, etc...)
2) Center of gravity is important to understand as well as fulcrums and force amplifiers. (Distance from fulcrum, etc...) Front end loaders are designed to place the actual working forces as close to the CG as possible, but moving them up or down can change the situation drastically in seconds. This is why counter balance rear of the rear axle is so effective at correcting problems associated with overloaded front axles.
3) Perhaps your front axle might not break of wear out right away if not using proper counter weighting, but it is safer, makes the tractor handle better, and keeps the front axle loaded within its working limits so I would suggest it. (And so as not to be accused of being a hypocrite, I do use my loader without counter weighting from time to time for light work, so shame on me.) :eek:
Stay safe everyone!
   / You need balast or you will trash your front axle!!!! really? #138
my:2cents:
Along that same line I will "fess up" to an almost disaster that happened to me on the last day I owned my Kubota L3400. I had picked up a rock that was at the limits of the loader. I don't know how much it weighed, but it was a big one. I was getting to place it into position on the rock wall the wife and I were building, when she said it would not fit, and she needed help from me with the bar to move another rock to make room for this one.
So I needed to dismount the tractor, and since I had quite a bit of trouble lifting this huge rock, I was reluctant to drop it back on the ground. I kept it up about a foot off of the ground, and set the parking brakes, and thought I had better drop my 3pt ballast, at that time about 750 lbs to the ground to also act as an anchor.
It turns out that dropping the 3pt ballast to the ground was not such a good idea, as when I dismounted the tractor on the slightly downhill side (the left) the tractor started to overturn. My weight in the seat was the only thing holding the rear on the ground after I dropped the 3pt counterbalance to the ground.
I was already on the ground as the slow roll of the tractor around the front axle pivot continued, I held the tractor from rolling over while the wife ran around to the other side and dropped the FEL load to the ground. Whew!, Disaster averted, but If I had kept the 3pt ballast up this would have never happened.
The 3pt ballast made all the difference in the world of planting those rear tires on the ground or letting them come up and allowing the roll around the axis of the front axle pivot bolt. Lesson learned. Oh by the way, the rear tires were also loaded with fluid, but still the high side rear tire was off of the ground over a foot. The sidehill angle was very slight, not much of an angle at all but it was enough when there is not enough weight on the rear to keep both rear tires planted.
   / You need balast or you will trash your front axle!!!! really? #139
I must admit, this discussion has been quite amusing to me because of all the theories and opinions expressed. I am a professional engineer, but will only make 4 comments:
1) The toy tractor on an egg scale is the best science project and analysis that has been submitted to this thread. This 'scaled' demonstration is frequently done for many, many, many such industry discussions. 1/4 scale models for wind tunnel measurements of racing cars is an example. This was a breath of fresh air from the list of stagnant, tired and wrong arguments.
2) My thoughts on this are: Loader work is really hard on tires and wheels because of the scrub while turning. And this is the main reason to have a ballast box. Tire wear goes up as the cube of load on them. Adding front air pressure is very important to maintain when heavy loads are carried by the loader. Even wheel fracture is possible as well as tire de-beading. Rear wheel spin is also a problem for tire wear. However, when using the tractor with loader, and 4 wheel drive, there can be large loads on the transmission because of the mismatch now between designed-for wheel rpm ratio. Some of you may find that its hard to change gears because of this internal loading. That's why 4 wheel assist is a benefit to loader work. The driveline strains are not as large. 4wheel assist is electric or hydraulic motor traction instead of direct shaft drive.
3) I doubt that a good , modern tractor designer has ignored potential foreseeable misuse (as its called in the trade) so there is plenty of reserve margin for axle housing size, weight, bearings, seals and fasteners. Tires and wheels, too. But I said a GOOD design, not a homeowner design where a loader is to be used to carry out the garbage cans every Tuesday.
4) The 'Math' behind all of this jaw boning would be taking Moments (force times distance) from any convenient single point in the side view and summing them up. Same analysis used to figure out where a previous threadster's trailer axle needed to be in order to reduce his tongue load. Yes, you need to include the tractor's wheel weights, center of gravity and total weight, loader content weight, ballast box weight and the distances from each point mass to the chosen central moment point. Then its just sophmore High School algebra.
   / You need balast or you will trash your front axle!!!! really? #140
Wow James that sounds like a hair raising experience! So the 3 point ballast would not have kept the rotation of the tractor around the front axle pivot from continuing?
Would have thought the 3 point arms/top link would at least keep the tractor from going over- unless it was to flip also?
I can't say that 3 point weight has not caused problems for me either...
One time trying to push dirt back with the Gannon boxblade the force caused an old weld to break on the left 3 point arm mount.
The left rear tire (14.9x 28) backed over the gannon and went up in the air (wife said 2 feet!) before I could get the clutch pushed in and slammed me into the ROPS ringing my bell pretty good.
Luckily No front axle damage was done :laughing: can't say the same for the mount on the Gannon and my pride,we all make mistakes and stuff does happen, hopefully we all learn from mistakes and experience.
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
2025 SDLANCH TRAILED CRUSHER (A58214)
2025 SDLANCH...
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56435)
2017 Rogator...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
