York Rake & Ice
/ York Rake & Ice #1
lawlopez
New Boson, NH
JD X450, Kubota BX23
Can you use a york rake (or any rake) on ice in winter to break the surface so it has more traction ?
I have a '93 Toyota/plow/poly edge, and have a BX23 & am working on getting the BX2750 working on it.
But I'm still thinking that sometimes just running the rake over the driveway might do some good things.
Just a thought.
/ York Rake & Ice #2
I do that when it's kinda soft and melting so i don't have a bob sled ride at 3 oclock in the morning when heading to work . it'll create some traction grooves.
/ York Rake & Ice #3
Interesting idea. I had that idea sort of with the ratchet rake.Id imagine the ratchet rake would get better cutting action
/ York Rake & Ice #4
I have a York brand rake and the teeth are square cut. I don't think that it would scratch the ice. Also the 3ph does not apply down pressure. The only down pressure is due to the weight of the rake.
As an aside, a york rake is terrible at raking leaves.
/ York Rake & Ice
I once used a Subaru with studded tires just before a box truck came up the driveway. Surprised the heck out of me when he made it up the driveway.
I also threw some sand around (by hand).
/ York Rake & Ice #6
I've used a rototiller on an icy driveway before, and it worked beautifully. Gravel drive though, wouldn't do it to a paved surface.
2" of ice on a hill I couldn't walk up went to slush and clear gravel instantly. Did it hurt the tiller? A bit. But with my use its still going to rust before I use it up... I'd rather put $5 of wear on my tiller than trash my new pickup
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
JCB 3TS-8T TELESKID (A65053)
JCB 3TS-8T...
HARDEE 16' T/A TILT BED TRAILER (A64278)
HARDEE 16' T/A...
2022 EZ-GO ELITE...
