Rake York rake help
/ York rake help #1
paulyny
I have a 6 foot york rake and have never been very successful using it. Its on a Kubota B8200. First off, i cant get it properly level at all heights, 2 to 3" lower on one side. I suppose the linkage is a bit worn on the 3 point. However, this rake has 2 wheels that follow behind. I have never used the wheels and am wondering what the purpose of them is. Im not working with truckloads of fresh topsoil. I usually filling in 20' depressions from trees stumps i removed in the past. Im working the 3 point up and down as i spread dirt which probably isnt right. Any suggestions.
/ York rake help #2
The wheels are designed to follow the contours of the land and avoid the rake digging in and causing depressions in the soil. If you use them and have them properly adjusted they work well to level the area if it is flat, or evenly spread the soil if the land is sloped.
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
8ft. Teak Wood Table (A61569)
8ft. Teak Wood...
2025 Hercule 40 Gun Safe (A61569)
2025 Hercule 40...
2016 Toyota Camry Sedan (A61569)
2016 Toyota Camry...
2014 Freightliner M2 106 T/A Terex Commander C6060 60ft Digger Derrick Truck (A60352)
2014 Freightliner...
