Rake York rake help
/ York rake help #1
paulyny
I have a 6 foot york rake and have never been very successful using it. Its on a Kubota B8200. First off, i cant get it properly level at all heights, 2 to 3" lower on one side. I suppose the linkage is a bit worn on the 3 point. However, this rake has 2 wheels that follow behind. I have never used the wheels and am wondering what the purpose of them is. Im not working with truckloads of fresh topsoil. I usually filling in 20' depressions from trees stumps i removed in the past. Im working the 3 point up and down as i spread dirt which probably isnt right. Any suggestions.
/ York rake help #2
The wheels are designed to follow the contours of the land and avoid the rake digging in and causing depressions in the soil. If you use them and have them properly adjusted they work well to level the area if it is flat, or evenly spread the soil if the land is sloped.
24220 (A56859)
24220 (A56859)
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2017 Case CX145D (A62177)
2017 Case CX145D...
2013 Ford Escape AWD SUV (A61569)
2013 Ford Escape...
2013 Mercedes-Benz E-Class Passenger Car, VIN # WDDHF5KB8DA693077 (A61569)
2013 Mercedes-Benz...
