Loader YM3810D Loader Information needed
/ YM3810D Loader Information needed #1
wild1bill
Pittsboro, NC.
Mitsubishi MT2501D Yanmar YM3810D
My YM3810D needs a loader. Fredricks sells a Koyker 160 with/for their 3810D. Does anyone know more about these or other possibilities for fit? Don't seem to be able to find info on hyd. flow rates for my 3810D so don't know how to compare that part. I understand that a JD 1050 is 'similar' but that may be like comparing two people(?). I'm told that the JD has about 37hp and that the Yanmar has about 45hp. I have extremely stout brackets on the tractor from some(?) loader that I may be able to adapt to something I find. Ideas are very welcome.
Don't give up.
/ YM3810D Loader Information needed #3
I have a 160 on my 3110. it's a descent loader. I broke it the other day and had to repair
/ YM3810D Loader Information needed #4
I had the 160 loader on my YM3000 and it was great. No problems whatsoever. It would lift way more than the tractor was built for, so I adjusted the relief valve to lift the front end of the tractor as a load limit. I understand, from Hoye Tractor, that Yanmar made 2 different hyd pumps for this series of tractors, smaller one for tractors with just the 3 point, larger one for those with a loader. Mine went out, and so I replaced it with the larger output pump. ( same physical size ) Speed of the loader was more than doubled. The smaller pump worked just fine, but the loader moved slow. You could have this problem with any loader you choose to install. The good news is that the replacement pump isn't to expensive.
Chris
/ YM3810D Loader Information needed #5
Yes what winston1 said I installed a coldwater loader on my yanmar 2000 fit like a glove and the loaders are built very strong great people to work with.
White Metal Roof Vents (A64194)
White Metal Roof...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2014 PUMA  END DUMP TRAILER (A65643)
2014 PUMA END...
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
