YM336D bad knocking engine
/ YM336D bad knocking engine
Yes, I read Domush's original post and then his later one after he ran low on oil. I got a lot of what I've been able to do so far from his posts and all of your alls replies. No fears of me getting upset about someone posting something that I'm doing, I admit I don't know what I'm doing. I actually took this to a mechanic who kept it over last winter. He finally admitted he didn't think he could work on it because it needed special tools...maybe he was just worried by the fact that it was a Japanese tractor. What I've read from you all and what I've seen first hand is that it is fairly simple....except I don't know engines that well. These tractors are put together well and "user friendly". I'm a little nervous about the valve cover job, but I'm going to tackle it this weekend.
Thanks already everyone.
Winston, this is perfect. I have been asking around and getting advice, but this is exactly what I need. I'm sure it won't be as easy as this, but at least I have an idea of what I'm doing.
Thanks, Ed
/ YM336D bad knocking engine #24
Here is a simple way to check your valve clearance. Easiest way to set the valves on your Yanmar
I believe your 336 is to be .006" if you decide to check them.
Hoye to the rescue!
I remember my Pa doing this to an old Dodge when I was a kid. IF he could do it, then anyone can. He mostly changed his oil and brakes, nothing else that drastic.
OK, I have gotten in and removed the valve cover. After disconnecting the few pieces I needed to, I discovered that the bolts holding down the valve cover were only hand tight at best. To my surprise, it was still very clean inside.
The valve on cylinder 1 and 3 had some play. Valves on cylinder 2, however, were very tight. thatç—´ the cylinder giving me problems right now.
To turn the engine, do I need to remove the radiator and fan? And do I need a special tool to turn the engine To get #2 to TDC?
I値l post a picture as soon as I go t YM 336D valves from Left side.jpgYM 336D valves from Right side.jpgo my computer. I can稚 seem to do it from my phone.
Wow, this may not come as news to you all, but I am obviously not a computer wizard.:laughing:
Ed
/ YM336D bad knocking engine #27
You should be able to get to the crank bolt without removing the fan or radiator. Find a socket that fits the nut, and a semi long ratchet or breaker bar and as short an extension as you can and have clearance to fit into the area. It might be a tight fit but you should not need to disassemble anything to turn the engine.
Reread the directions from the Hoye link that Winston shared and then go to it.
Ok, thanks. I wasn稚 thinking I壇 be able to get in there. I was also looking in the wrong place, I値l give it a shot. Thanks again.
/ YM336D bad knocking engine #29
Yea you can fit a deepwell or socet and what extentions you need if necessary.
You may be able to grab the fan and belt pulley to roll it by hand but it may just slip from the compression.
/ YM336D bad knocking engine #30
you said it started knocking AFTER you washed it, that points to water getting into the computer, there's nothing mechanical that would be affected by a wash..
Computer?? What computer? I don't disagree with your thinking, because it certainly was running fine before the wash, but what computer is on this 1984ish YM336D?
I'm seriously asking, because one thing I like about this tractor is it seems so simple and I thought that was because it didn't have all the modern computers running it.
/ YM336D bad knocking engine #32
IT DOES NOT!
All of your sending units are mechanical/electrical components.
NO ELECTRONIC ONES!! All you need on it to test any electrical issue is a 12volt test light.
Change of subject, but both valves being tight at the same time on that cylinder is a dead give away to your miss! Both loose is compression and fire strokes. Then you have 1 or the other loose/tight on intake (tight) stroke or exhaust (tight) stroke.
Check the gap on all 6 while it is apart. I have not looked this up so if I am wrong someone chime in (Winston) intakes are 0.006” gap and exhaust 0.008”
You are correct. The little yellow sticker was still on my valve cover and it says .006" when cool. By you saying it's a dead give away, do you mean that one of the valves is obviously too tight because you should never have both open (tight) at the same time? Or is this indicative of something bigger?
And I really do appreciate everyone who has chimed in. It sucks for you all that I'm learning this as I go, but I will learn this and pass it on when others need help.
/ YM336D bad knocking engine #35
There is NO computer on this tractor. It's ALL MECHANICAL!!:D:confused3::laughing::thumbsup:
/ YM336D bad knocking engine #37
If both valves are tight at the same time, both are open to the cylinder at the same time. This is a condition that should never happen if all is correctly set. There are 4 strokes: intake (intake valve open—rocker arm tight, exhaust closed—rocker arm loose-0.006”) compression both valves closed—rocker arms loose, fire both valves closed, exhaust (exhaust valve open—rocker arm tight, intake valve closed—rocker arm loose)
When I state rocker arm loose I mean that 0.006” clearance with the spring fully extended as assembled. It should wiggle slightly with your fingers.
Again I recommend doing all 6 valves while you have it apart.
With one cylinder remaining open at all times you have a misfire setup regardless of which stroke both valves are open on, likely 1 valve stays open on all 4 strokes.
/ YM336D bad knocking engine #38
Hopefully, the out of adjustment valves are not sufficiently so to cause greater troubles.
I have to confess my ignorance at this point, I do not know if these are an interference motor or not. An interference motor is one where a missed time valve (overly tightened rocker arm in this case) will result in the piston head and valve contacting one another. Many things can happen in this situation:bent valve, hole in piston, broken valve,
Either of the last 2 could result in pieces of metal in the cylinder doing even more damage.
At this point, we know at least 1 valve is out of spec. Correct this problem and then see what the status is. It is a diesel so no easy way to look in the cylinder. A bore scope through the injector port is easiest, you have experience with the injector pulling. But I would adjust the valves (all 6) and go from there on how it runs.
Coy, great explanation. I understand the basics of the 4 stroke, but this put it into perspective for my particular problem. I have to get a deep well 17MM socket...I hope...to turn the engine over. It is very tight, but I think I'll be able to do it with a deep well. Thanks again.
/ YM336D bad knocking engine #40
Good luck with and hopefully no damage from any contact with internal parts.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Prime 283 (A64126)
Prime 283 (A64126)
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
