YM3110 question
   / YM3110 question #1
paulBurns
Carroll Co Tn
Ym3110
This week I bought one and do not have a manual as of yet. I used it several hours today with a tiller and could not get the tiller to go to a set position easily. Rasing the lift lever resulted in the tiller not responding for a while then it would go all of the way up not just a little. Same thing on the lowering. I could not set the depth with any accuracy at all with the lift lever. Thanks for your thoughts.
   / YM3110 question #2
sounds like you don't have position control on your tractor, some don't- either up or down, no inbetween
   / YM3110 question #3
Unless you know for sure when the last time the hy/trans pickup screen was cleaned and fluid changed, I would start with that. A dirty screen can cause the erratic behaviour you describe. You should be able to tap the lever up or down and move the implement by fractions of an inch.
Killbros 260 Seed Conveyor (A52748)
Killbros 260 Seed...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
2016 Bobcat E85 Midi Excavator (A50322)
2016 Bobcat E85...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400lb 3 Ton Mechanics Crane Service Truck (A50323)
2013 Ford F-550...
Trail-Sport TS21RBH RV (A50121)
Trail-Sport...
