YM2500 or YM2610 Alternator
   / YM2500 or YM2610 Alternator #21
When I researched that long ago, the AC version alternator for 73 Datsun was larger diameter. I read somewhere that this wouldn't fit so I measured where it would go, and concluded it could be solid against the block and the existing adjustment strap still wouldn't reach out far enough.
It sounds like today's alternator has 35 amps in what used to be a 25 amp shell.
But unless you are night plowing or moving snow, I don't see a need for more amps. Especially with the LED bulbs used now. The original 15 amps is sufficient to just maintain the battery for starting - for daylight work.
If I wanted to add a front plow with an electric linear actuator, then the power would be there.
Motorcycle (A59231)
Motorcycle (A59231)
40' CONTAINER (A58376)
Giyi Mini Auger (A57149)
Giyi Mini Auger...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
