YM2210D compression release
/ YM2210D compression release #1
souperbee
Melrose/Grandin/FL.
Yanmar YM2210D
I have a question about the compression release. Is it only used for cold weather starting? Or do you use it all the time? I use it all the time figuring it is easier on the starter. Am I doing it right? Thank you for any help you can give me.
/ YM2210D compression release #2
The only place I find the compression release mentioned in my manual is in the section on cold weather starting. However there are two camps on that question. One says "cold weather", the other says "all the time". I've tried it both ways during warm weather but my 2220 starts so easily that I put more wear on the starter spinning it up with the compression released than I do starting it from scratch.
The most logical argument I've heard in favor of using the comp. release in all starts doesn't have anything to do with starter wear. The argument is that using it gets the oil pressure up and flowing before compression and combustion pressures are applied to the various bearing surfaces thereby reducing wear on the engine. Sounds reasonable but I cannot testify either way as to any long term significant effects.
FWIW, I'd say do whichever gives you the warmest fuzzies.
/ YM2210D compression release #3
While I would be of the opinion that it is primarily for cold weather starting there is one advantage to using it all the time and that is that if there perchance is oil or water on top of the piston it will push it out and not have the potential for piston/rod damage from trying to compress the incompressible. :eek:
It does take longer for the spin up to oil pressure than it normally takes for my engine to start without using the release. More starter wear vs more engine wear? I do not know--it is a lot lighter load without compression and good oil clings to the bearing surfaces quite well.
Let every man be convinced in his own mind I say.
Mike
/ YM2210D compression release #4
I use mine all the time. Adds maybe ten seconds of extra starter wear for the oil light to go out.
Bruce
MJPetersen said:
One advantage to using it all the time and that is that if there perchance is oil or water on top of the piston it will push it out and not have the potential for piston/rod damage from trying to compress the incompressible. :eek:
Mike
I didn't think about that, but that is a much better reason to use it all the time since my tractor doesn't have the oppurtunity of being garaged. I should have my garage up in a couple of months then it will be a different story. Thank you for bringing that to my attention.
/ YM2210D compression release #6
Another reason to use it all the time is get the oil pressure up before you start the engine. This will increase the life of your engine. Shut ur fuel off, open your comp release and operate your starter for about 9 seconds. Wait one minute and turn your starter again this time watching your oil pressure light if it goes out before another 9 secs open a little fuel and pop that release...she will fire right up and have lubercation......geniuous....
/ YM2210D compression release #7
greatrandini said:
...turn your starter again this time watching your oil pressure light if it goes out before another 9 secs open a little fuel and pop that release...
You know, I've tried doing something like that, but as I recall, all the warning lights on my machine go out as soon as the key is turned to the start position. I guess some machines are wired differently than others.
/ YM2210D compression release #8
I think that if this was the case, all engines would have the compression release. I've owned and driven a lot of farm tractors and the Yanmar is the first I've seen with it,
/ YM2210D compression release #9
I have added gauges to my yanmar. The oil pressure is above 30 psi in about 5 to 6 seconds of cranking before releasing the compression release.
I strongly believe that this practice adds greatly to improved bearing life.
/ YM2210D compression release #10
Well Eddie, I don't know what to tell ya! I did not make it up so argrue with Yanmar about it....... How ya doing any how? We got our first snow here.
/ YM2210D compression release #11
The gauges are proof for sure. I also believe that the pressures and drag exerted by a diesel engine to a starter are far more damaging then to cycle the starter freely when the decompression is used.
/ YM2210D compression release #12
this makes sense the diesel engines in locomotives basically have vents on them to open and cycle the engine a few times before starting to push any moisture out of them if not done over time will blow head gaskets. ive seen this happen.(according to the mech that repaired the motor that was the reason atleast) here in louisiana the humidity is pretty high so i can see this being worth while to save wear and tear on the motor but at the same time like said before there are plenty of diesel motors in other equipment and vehicles that dont have this option that last a long time.
Unused 2021 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
Unused 2021 Ideal...
2015 PETERBILT 389 T/A 6X4 SLEEPER TRUCK TRACTOR (A69167)
2015 PETERBILT 389...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A66736)
2015 International...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2006 Ford F-750 Terex Commander C4047 Digger Derrick Truck (A68183)
2006 Ford F-750...
