YM2210D compression release
/ YM2210D compression release #11
boonesmith said:
I have added gauges to my yanmar. The oil pressure is above 30 psi in about 5 to 6 seconds of cranking before releasing the compression release.
I strongly believe that this practice adds greatly to improved bearing life.
The gauges are proof for sure. I also believe that the pressures and drag exerted by a diesel engine to a starter are far more damaging then to cycle the starter freely when the decompression is used.
/ YM2210D compression release #12
this makes sense the diesel engines in locomotives basically have vents on them to open and cycle the engine a few times before starting to push any moisture out of them if not done over time will blow head gaskets. ive seen this happen.(according to the mech that repaired the motor that was the reason atleast) here in louisiana the humidity is pretty high so i can see this being worth while to save wear and tear on the motor but at the same time like said before there are plenty of diesel motors in other equipment and vehicles that dont have this option that last a long time.
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
2024 GMC Seirra Elevation Crew Cab 4X4 Pick-Up Truck (A60352)
2024 GMC Seirra...
2025 MMS MS36C (A60463)
2025 MMS MS36C...
2019 F150 (A61306)
2019 F150 (A61306)
