YM2020D with v2 loader - Should I buy?
   / YM2020D with v2 loader - Should I buy? #21
It's easy I just look at my steering wheel!
   / YM2020D with v2 loader - Should I buy? #23
Mitsubishi mt16fd with yanmar steering wheel.I don't think the steering wheel is mitsubishi issue.The tractor was a gray rebuild so far 50 hrs by me 75 hrs total.Knock on wood,just an ignition switch and thermostat.Otherwise it runs great I am hoping to make the150 hr mark.
WHOOO HOOOO....I may just howl at the moon tonight.....I did it....I pulled the trigger and bought the YM2020D, brush hog and back blade.
Has a couple gremlins.....lights and needs a new front axle seal....but she looks like she is a keeper! Here is a shot of me unloading
More photos are located here:
Yanmar YM 2020D pictures by divedivediver - Photobucket
   / YM2020D with v2 loader - Should I buy? #26
Congratulations on the YM2020D! with the leak in the front axle, I had a similar issue with my YM169D and after it dumped oil all over the garage floor I decided to get a new seal. It does take some time and the right tools to fix, I spent several afternoons working on it until it was actually fixed. Luckly for me JD's 650 has the same front axle so I was able to get a new seal for it.
   / YM2020D with v2 loader - Should I buy? #27
Hoye also sells parts and seals so its not like a jd dealer is your only option. My guess is hoye is cheaper than jd as well.
   / YM2020D with v2 loader - Should I buy? #28
Congrats, l;ooks like a good tractor and well kept, should make u a goodun.
   / YM2020D with v2 loader - Should I buy? #30
If the seal is not pouring you might want to try the Lucas power steering stop leak. Many successful stories with it. Nice looking ride!:thumbsup:
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
vin:16VEX2023H3042174 (A50322)
vin:16VEX2023H30421...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2013 Honda CR-Z Hatchback (A50324)
2013 Honda CR-Z...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
