YM2020D with v2 loader - Should I buy?
   / YM2020D with v2 loader - Should I buy? #21
It's easy I just look at my steering wheel!
   / YM2020D with v2 loader - Should I buy? #23
Mitsubishi mt16fd with yanmar steering wheel.I don't think the steering wheel is mitsubishi issue.The tractor was a gray rebuild so far 50 hrs by me 75 hrs total.Knock on wood,just an ignition switch and thermostat.Otherwise it runs great I am hoping to make the150 hr mark.
WHOOO HOOOO....I may just howl at the moon tonight.....I did it....I pulled the trigger and bought the YM2020D, brush hog and back blade.
Has a couple gremlins.....lights and needs a new front axle seal....but she looks like she is a keeper! Here is a shot of me unloading
More photos are located here:
Yanmar YM 2020D pictures by divedivediver - Photobucket
   / YM2020D with v2 loader - Should I buy? #26
Congratulations on the YM2020D! with the leak in the front axle, I had a similar issue with my YM169D and after it dumped oil all over the garage floor I decided to get a new seal. It does take some time and the right tools to fix, I spent several afternoons working on it until it was actually fixed. Luckly for me JD's 650 has the same front axle so I was able to get a new seal for it.
   / YM2020D with v2 loader - Should I buy? #27
Hoye also sells parts and seals so its not like a jd dealer is your only option. My guess is hoye is cheaper than jd as well.
   / YM2020D with v2 loader - Should I buy? #28
Congrats, l;ooks like a good tractor and well kept, should make u a goodun.
   / YM2020D with v2 loader - Should I buy? #30
If the seal is not pouring you might want to try the Lucas power steering stop leak. Many successful stories with it. Nice looking ride!:thumbsup:
2014 Landoll VT-Plus (A52349)
2014 Landoll...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
International 5088 2wd Cab Tractor (A52128)
International 5088...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
Kubota RTV-X900 Utility Cart (A50322)
Kubota RTV-X900...
