YM2010 Electrical Help
   / YM2010 Electrical Help #1
ufengineer
Bronze Member
Jacksonville, florida
ym2010
My dynamo wasn't charging my battery. The dynamo tested out okay. It was producing 16.8 volts AC at around 1000rpm. I tested the regulator and it tested bad. I replaced the regulator and still the system isn't charging. I started the tractor, removed the positive lead from the battery and checked the voltage (wont do this again). I got no reading. I noticed that the two wires coming from the dynamo were getting warm/hot. Do I have a short somewhere.
Any ideas where to start? I removed the wire wrap from the wiring harness in the engine compartment which was pretty easy to do because it was very brittle. The wiring looks fine. I removed the dash and started inspecting the wiring there but ran out of daylight.
Any ideas would be greatly appreciated.
   / YM2010 Electrical Help #2
Don't know I can be of much help. Do you have a wiring diagram? The two wires out of the dynamo go straight to the regulator. Thinking they are blue. Also thinking the black wire on regulator is ground. Thinking maybe two reds coming out of regulator that should be showing 13+dc when running. Thinking the green/yellow goes to the charge light. Giving these colors out of a 226 parts manual but thinking yours may be the same.
Are you showing any dc voltage at your regulator. I believe one of the red wires should be showing battery voltage running or not.
Thanks Winston. I have a wiring diagram. I need to check the voltage at the regulator next.
I checked the regulator. With the engine off and the key in the on position I'm getting 12.6 volts from the yellow, green and red wire. The black ground also has conductivity.
   / YM2010 Electrical Help #5
You checked the dynamo for voltage and made mention of the wires getting warm/hot. Did you check the voltage at the dynamo or where the wires enter the regulator? Maybe something going on between the dynamo and regulator? :confused3:
Referencing the attached, the problem would have to be in the red wire going from the regulator to the starter/battery. But, does the charge go through the ignition switch or straight to the starter??? 20151126_080529.jpg
   / YM2010 Electrical Help #7
It goes straight to starter (red to B), and straight to switch, (white/red to 30). Effectively goes through starter B to switch 30.
So to check the charge line I would check the conductivity of the red wire coming off the regulator to the starter?
Would a short anywhere else disable the charging circuit? I don't think so. Would a short in the ignition switch disable the charge circuit? I removed the dashboard and the gauges. I should be able to start the tractor and check the charge circuit. Or, does the dash and gauges need to be connected?
   / YM2010 Electrical Help #9
Probably have checked but I will ask again. Did you check the dynamo wires where they enter the regulator making sure the ac voltage is reaching the regulator. If it is and no charge I would start suspecting the regulator.
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
New Bobcat 18" Bucket (A50774)
New Bobcat 18"...
