YM2010 Electrical Help
/ YM2010 Electrical Help #13
I get from your posts that the overheating wires started after you replaced the regulator. either the new regulator is shorted or it is wired incorrectly. I would put the original reg back in and start from the beginning.
Thanks everybody. There was a short in one of the plugs. I'm getting 13.8 volts at the battery now. Pissed at the guy that I purchased the tractor from for removing the bulb to hide the issue. Jack ***.
/ YM2010 Electrical Help #17
Glad you are up and running. Was the original regulator bad?
Winston
The original regulator is good. The issue was the plug all along. It looks to be the original regulator. I used the test procedure in the shop manual and it tested bad. I tested the new regulator and it tested bad too. I think the procedure is flawed. ; )
/ YM2010 Electrical Help #19
If there was a "short" in the plug, what was it shorted to. Or did you mean a bad connection. I have gone through several of these damned regulators and now I just leave it disconnected and use a deep cycle battery and charge it occasionally. The alternator mod seems like the best solution. Any one have a good source for parts to make that happen?
prs
/ YM2010 Electrical Help #20
Winston
I too had trouble with that test being conclusive.
208316 (A58375)
208316 (A58375)
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2020 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2020 Kubota...
