ym2002d alternator possibility
/ ym2002d alternator possibility #1
winston1
Super Member
gilmer tx
Bobcat CT235
I just had the 3rd voltage regulator go out on my tractor yesterday. One before that was about a year ago. One before that was 3 years ago. I'm tired of this expense. It uses the vr522. My research has told be there is no other replacement available. Therefore I am entertaining the idea of installing an alternator and doing away with my little dynamo. I have two possibilities in mind.
First is this DB Electrical - NEW CHEVY MINI ALTERNATOR DENSO STREET ROD RACE 1-WIRE 12180 with the dimensions shown. I know this alternator has been used successfully on a GT14. My compartment looks very similiar.
Second is this New Alternator John Deere Tractor 655 755 756 855 856 12188 | eBay without the dimensions shown. Both of these alternators look very similiar. The second being rated 5 amps higher.
Any of you electrical gurus out there please tell me if I can hook up my charge light to these? I think they are classified as one wire but both have two spade connectors on the back.
Anyone out there have that second John Deere/Yanmar in use that could give me any dimensions?
Here is an old thread from a different forum on an install. Mine looks very similiar. Hoses and all. Converting to GM Alternator - Net Tractor Talk
/ ym2002d alternator possibility #2
What do you think is causing all the VR'S to go bad ? Are all the VR's the same meaning does the same vr that fits my 3110 fit your tractor ? I'm going to knock on wood to say this .but I haven't had no problems with my original charging system for the 7-8 yrs I've had the tractor. I'm sure that with your abilities you'll get something to work
/ ym2002d alternator possibility #3
i put a hitachi alt on my 1700.. uses an old style (chrysler) external reg.
alt was the same size as oe. a gm delco cs130 would liekly fit too.. cost more.. etc... no external reg though..
/ ym2002d alternator possibility #4
I suggested this to you on another forum, yes your charge light can still be connected. if mine ever dies i also will go down this path. Go for the biggest capacity in the smallest package you can find.
I don't have a clue what is causing them to go out. A gentleman on another forum suggests possible "gound short". Not sure just what that is? There are at least six different regulators. Yours uses a vr550. It is a solid state also. He gave me some testing ideas to try. Anything I find I will post.
/ ym2002d alternator possibility #6
Fuse Panel on my 2000. Connection on the back for the Chrg. Sys. I still have the old style in the dash and a SS. Reg. which I use. Been over 5yrs. without a Prob.. I was lucky to have seen the Chrg.Light Flicker a few times which is the reason I was Checking the Cir.. After correcting it Hooked the Old reg. up and Wahla.. it still works fine. Also let me add that a big chain auto checked the SS.reg. and said it was bad. :rolleyes:
I pulled my fuse box off this afternoon, pulled fuses, cleaned all connections and reinstalled. No difference. This is the fuse box I have. Yanmar Tractor Parts: FUSE BOX ASSEMBLY The ac voltage from the dynmo goes straight through the regulator before going to the fuse box. That being the case it would seem to me I should get raised dc voltage right out of the regulator whether the fuse box is a problem or not. Just getting battery voltage. :(
/ ym2002d alternator possibility #8
My friend has an 855. if i can get over there, if no one else responds i will get you dementions of it. Untill then keep battery on a trickle charge and you will be good to go.
/ ym2002d alternator possibility #9
Could it be the generator shorting out ( intermittently ) causing the VR to blow ? I'm just thinking out loud. If tractor is like mine ,there's not much wiring to have to deal with. Good luck what ever you decide !
/ ym2002d alternator possibility #10
i dont think its a short in the accessories either. check your earth on the reg and the body, ensure its spotless and grounding well. check the positive back to the ignition/starter where it terminates. check to see if the wiring out of the reg to and from everything has not worn through anywhere that it could earth out. barring all that i think its just plain bad luck with them?
/ ym2002d alternator possibility #11
Hey Winston I am certain you cant use the 1 wire hot rod alt with a chg lite since the excite circuit is built into that ones regulator. The lite is the excite circuit in most others its a simple but lengthy explanation and not necessary here.
edit: not saying it wouldn't work just wont operate your chg lite not sure if that was clear or not probably not knowing my comm skilz? it sure would work to charge the battery though, you would just need to add a volt gage if you wanted verification it was charging. ;)
Any other alt could be used just wire the light (excite) circuit into (normally the #1 terminal) and wire the #2 terminal (battery volt sensing circuit) back into the big output terminal on the alt. Then the only wires are the lite wire (3 ohm load IE small light bulb in key on position) and the big wire going to the B+. I have a little nippondenso alt off a Toyota pickup ready to go on mine if I get around to it fwtw. hth
Size is of utmost importance here. Is the one you have as small as the hot rod? If so, do you have a part number for it?
/ ym2002d alternator possibility #13
Good question. I guess I haven't had them side by side to know which is smaller? but the application for mine is mid 90's 4Runner and pickup v6 its a very common alt.
ok here is some specs-part # 27060-65040, its 6" from ft edge of pulley to back plate, its 7 1/4" bolt to bolt center line, its 5" in diameter. seem to think its 80-100 amps but that is immaterial in this application. has a 3 wire plug in ign, sens, lite. and b+ of course.
Cardoc, I am going to attach a thread from another forum where a guy put one on a gt14. Maybe you can comment on what you see there. If I am understanding it right he says the charge light will work. I sure don't know and don't want to order something that won't work. I guess it is sort of long and you may not want to mess with it. I'm afraid the one you have will not fit in my compartment. Converting to GM Alternator - Net Tractor Talk
Gt14 actually has a thread on this forum but the one I attached has the pictures already showing.
/ ym2002d alternator possibility #15
You have to be registered to view the pictures. if it fits in a GT it will easily fit your 2002D. the GT/YM 14 has no room around or behind its pancake alternator, and i mean no room :thumbdown:
Here is the related thread on this forum. http://www.tractorbynet.com/forums/yanmar/106525-installing-alternator-instead-generator-ym146.html I had actually placed an order right before Cardoc's response. I got back in touch with them and asked them to put it on hold but it may already be shipped. Guess I will find out something today. I could not find a phone number to call. I don't suppose it would be that expensive or difficult to install a voltmeter on the dash somewhere. Thoughts? Something like this work? In-Dash Voltmeter
/ ym2002d alternator possibility #17
I was thinking very hard about replacing my dynamo when I was adding extra lights. I ended up adding LED's so I kept the dynamo. I also installed some gauges winston and I have added some pictures. I also came across (I cannot remember who wrote this up) hand drawn schematic and picture of adding an alternator (datsun). It might help you.
That hand drawn schematic looks identical to what I have to go with.
/ ym2002d alternator possibility #19
To the original poster... alt model used will determine if the idiot lamp can be used or not, even if the alt is a 1-wire self exciter. I've installed MANY delco 10si and 12 SI alternators. Plenty of those were bought as 1-wire, self exciting vr modules. I've YET to see a case where i have not been able to pry out the plastic cover over the 1/2 terminals, loop 2 to the charge stud ( may not be needed on all modules ), and then run 1 to a charge light, then to switched power.
Idiot lamp always worked as advertised.
Not saying there are no vreg modules out there for them that won't do this.. just the ones I've installed on countless tractors have worked this way. PS.. even on the 1-wire alts that self excite... with an idiot lamp hooked up, I have not found one yet that would not excite at a low 400-450 rpm.. vs a higher rpm for self excite.. sometimes from 800-1200 rpm.. etc.
/ ym2002d alternator possibility #20
(not sure why I am being quoted here or what the point is humm...)
Ok let me get this straight-you are saying we go buy a specialty 1 wire (when 2 and 3 wire are the same price or less and even more plentiful) spend the time to tear it down, more than likely lose the warranty tearing the paper tag or security paint dab on a bolt head and then hope we dont switch the wrong wires frying the reg and eating that alt or buying a new regulator for it when that's all he needs now is a reg for his old dynamo?
Holy bench vice batman! :laughing: (si alternators are way to big for this application anyway cs may be better and more expensive possibly but the import alts are better sized imho fwtw)
CF Grapple (A64127)
CF Grapple (A64127)
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
John Deere 672GP (A64126)
John Deere 672GP...
