YM2000 Temp & Oil Guage upgrade
   / YM2000 Temp & Oil Guage upgrade #1
Mslater
Baton Rouge LA
YM2000
Can someone tell me what size fitting to look for when purchasing a gauge upgrade. Mechanical or electrical gauges? Any particular brand work better/fit? I was looking at the tri gauge setup from good ole autozone. Thanks!
I can't believe I misspelled gauge 4 times!
   / YM2000 Temp & Oil Guage upgrade #3
Do a search of the Yanmar forum, and you'll find several very informative threads on this subject. Most prefer mechanical, Sunpro makes a metric adapter kit that will connect their gauge to your 2000...even if you want guages instead of gauges. /forums/images/graemlins/grin.gif (as if I'VE never misspelled it before!)
I managed to find the sunpro adapter kit for the oil sender and am happy to say it works nicely. The ole girl is running at about 32 psi @ 1000 rpm idle. Unfortunately I can not locate the adapter kit for the temp sending unit. I am going to attempt to locate just a bushing/adapter from napa or something. Looking good so far!
   / YM2000 Temp & Oil Guage upgrade #5
Mslater,
If I remember right; when I installed the gauges on my 1700 the adapter for the oil was seperate from the temp. I had several adapters left over out of the pack for the oil and the adapter for the temp was by itself. I got everything from Autozone for about $50 (gauges and adapters) and would think that the same adapters would be used for the 2000.
I ended up getting a adapter kit from orielly that had a 1/2 to 16mm and it seems to work fine. No leaks that I can see.
2025 12v Diesel Pump, Hose And Nozzle (A50323)
2025 12v Diesel...
International 3500 Backhoe (NOT RUNNING) (A50774)
International 3500...
2012 Ram 1500 Crew Cab Pickup Truck (A50323)
2012 Ram 1500 Crew...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
2003 Chevy 2500 Pickup (RUNS) (TITLE) (A50774)
2003 Chevy 2500...
