YM2000 Temp & Oil Guage upgrade
   / YM2000 Temp & Oil Guage upgrade #1
Mslater
Baton Rouge LA
YM2000
Can someone tell me what size fitting to look for when purchasing a gauge upgrade. Mechanical or electrical gauges? Any particular brand work better/fit? I was looking at the tri gauge setup from good ole autozone. Thanks!
I can't believe I misspelled gauge 4 times!
   / YM2000 Temp & Oil Guage upgrade #3
Do a search of the Yanmar forum, and you'll find several very informative threads on this subject. Most prefer mechanical, Sunpro makes a metric adapter kit that will connect their gauge to your 2000...even if you want guages instead of gauges. /forums/images/graemlins/grin.gif (as if I'VE never misspelled it before!)
I managed to find the sunpro adapter kit for the oil sender and am happy to say it works nicely. The ole girl is running at about 32 psi @ 1000 rpm idle. Unfortunately I can not locate the adapter kit for the temp sending unit. I am going to attempt to locate just a bushing/adapter from napa or something. Looking good so far!
   / YM2000 Temp & Oil Guage upgrade #5
Mslater,
If I remember right; when I installed the gauges on my 1700 the adapter for the oil was seperate from the temp. I had several adapters left over out of the pack for the oil and the adapter for the temp was by itself. I got everything from Autozone for about $50 (gauges and adapters) and would think that the same adapters would be used for the 2000.
I ended up getting a adapter kit from orielly that had a 1/2 to 16mm and it seems to work fine. No leaks that I can see.
New Holland TN70D Tractor (RIDE AND DRIVE) (A50774)
New Holland TN70D...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2012 Cadillac CTS Sedan (A50324)
2012 Cadillac CTS...
2014 Kubota R520S (A50120)
2014 Kubota R520S...
