ym2000 question.
/ ym2000 question. #1
lancem
Martin,Ga
YM2000
Can anyone tell me if wile my tractor is running and I turn the key to the off position will the alternator still charge the battery. Thanks:)
/ ym2000 question. #3
Put a voltmeter on the battery with the key on and off and see what you get.
/ ym2000 question. #4
Don't ask how I learned this .... an old battery in poor condition will barely start the tractor if the key was off while you worked all morning before you stopped for lunch.
So no, there is no charging while the key is off.
/ ym2000 question. #5
Maybe mine has a short or something grounded that shouldn't be, but if I leave the key 'on' and not switched 'off' it will pull the battery down after a few sessions.
/ ym2000 question. #6
If the motor is running, which means the alternator is spinning then yes you are charging.
2017 John Deere XUV825M S4 (A64912)
2017 John Deere...
2012 Mercedes-Benz GL 450 AWD SUV (A66738)
2012 Mercedes-Benz...
330 GAL WATER TANK (A68842)
330 GAL WATER TANK...
BODY LOAD TANK (A67714)
BODY LOAD TANK...
2020 FREIGHTLINER M2 106 WATER TRUCK (A67714)
2020 FREIGHTLINER...
2012 KENWORTH TROAXLE BODY  LOAD (A67714)
2012 KENWORTH...
