ym2000 not charging
/ ym2000 not charging #1
E Tractor
North Carloina
Hey, I was working a YM2000 and decided to check the charging system. I put a meter across the battery and had only 11.8 volts. Not Charging. I took the alternator to 2 places but they were worthless as they had to have there part number to check it out. OF couse I did not have a number so I left. Anyway what do you guys do to check out a alternator and regulator? The wiring is pretty bad on the tractor as it is. I am just trying to see what I need to buy to get it up to speed.
thanks again.
erick
/ ym2000 not charging #2
Take to an old fashion alternator shop. They can check. These auto zones & such can't tell you anything unless it's on their computer.
/ ym2000 not charging #3
I got a Datsun 510 alternator and regulator and put on mine. It's been working great for about 2 years, at a cost of around 38.00 for both if I remember right.
Do a search in this forum and you'll find the details.
Jerry
ah ha. I thought a Datsun would work. I read it somewhere but could not remember. I wonder if you told the AutoDuds that they could check it under a Datsun 510 that they could check it? I was going to a old place next week that rebuilds them and can also check them.
thanks
Erick
/ ym2000 not charging #5
E Tractor said:
... I wonder if you told the AutoDuds that they could check it under a Datsun 510 that they could check it?
I'm certain the $65 replacement regulator for YM2000 tests identical to '72 Datsun 510. BTDT. I had already bought the regulator by mailorder so I didn't return it. I was tempted, but that dealer has always provided excellent service so I figured wasn't fair to return it.
I expect the alternator would test ok (or bad) if you told AutoZone it came off a 72 Datsun. Be aware the alternator Hitachi provided for YM2000 is only 15 amp while the one they provided to Datsun was 35 amp, so that might make a difference in the test result.
Eric, I have a question: does YM2210 use the same alternator and regulator as YM2000? Thanks!
I don't think the 2000 has the same as the 2210, the connectors are a little different on the back, just not sure but would say no..
I went to autozone and thought it bad but the guy just punched in some sort of numbers as a guess. I went back to Napa armed with the thoughts of a datsun 510 and even had the older guy help me. He checked many manuals and we tried to test it under something close and it failed. I was about to order a 510 altrernator but the guy said he would have to order it.
SO i went to a local old school shop that knew how to check with a volt meter! And low in behold it was good! the bearing sounded a little bad so for $40 bucks he would go thru it and fix that and double check it all out.
I watched him check it, He spun it on a machine and would get 11.5 to 12 volts with just checking the + and - but if you connected (not sure which one) one of the 2 plugins to the + it would go to full charge, 15volts in my case! SO good. he has my unit now and I will bring the regulator to him next. The wiring is so rigged I have to check them both as they could be good or not.
will let everyone know when i do.
later
erick
Well I got the alternator back and ended up buying a voltage regulator for $28 bucks. Pretty cheap. The place that rebuilt my Alternator could not test my old voltage regulator due to there machine being down. It probabaly was bad. Anyway I put them back on the tractor and it is now charging! hurray! Now the wiring is still a issue. I am having to get a new set of dash lights and turn signal switch, I might just go for a new starter switch as the one on it is the generatic crappy one. After looking over the wiring schematics for the ym2000 it looks really easy to work on. Just need more time.
later
Erick
/ ym2000 not charging #8
I knew if you took it to an old fashion atl shop they could test it . Auto Zones & the like If it ain't in the computer we don't know what to do.I remember when I was a teen growing up working on my cars. I could walk into a family owned auto parts store & tell the guy ( that had worked the counter all his life) that I needed plugs , dist. cap, rotor ,points & condenser for xyz auto & he didn't have to look in a book. He just went to the shelf & picked up all the parts & asked If I needed anything else. AH, the good ol days sure are missed ( atleast by me)
/ ym2000 not charging #9
... tell the guy ( that had worked the counter all his life) that I needed plugs , dist. cap, rotor ,points & condenser ... AH, the good ol days sure are missed
it's certainly different today. But I'm not convinced the old days were better. The only thing in that list that my Subaru has needed in 9.5 years, 88k miles is plugs, once. I don't know what's under its hood since I never needed to look.
'Back in the day', I used to teach automechanics.
/ ym2000 not charging #10
I was refering to mainly the folkes behind the counter. Now days you have to tell them what color it is , How many doors it has, 2wd or 4wd etc, etc,. & & if the engine wasn't the one that came in the car . you can forget it. Example>>>Had a drag car once 440ci in a dodge dart. try to buy a freeze plug for a 440 ci engine for a 1969 dodge dart. doesn't matter all 440 freeze plugs are the same . in their computer A 440 ci in a 1969 dodge dart don't exist
/ ym2000 not charging #11
No question about that! I went to Autozone for an oil filter, for my Ford Focus. The first and then the second one they sold me, were incorrect. Actually the lookup book was ambiguous.
But the previous oil change, I went to what I thought was a Real Mechanic. Until he insisted that all Focuses have six cylinder engines. I think in the US there are nothing but four cylinder Focuses. After he popped the hood he shut up. I haven't gone back.
But hey, we're pulling Etractor's thread offtopic.
Etractor, I'm glad you found a good shop!
oh yea when you modify something parts guys never have a clue. I had a suzuki samauri with all kind of crazy mods to it. Like 85 toyota axels, 16valve sidekick motor.
Oh the funnest one i had was when I lifted a 73 vw thing. Really beefy crazy looking car. I went in for a safty inspection at my normal shop and there machine was down so I went to jiffy lube. the guy there said his lift would not be able to pick it up!! He thougth it was a hummer or something like that! I explaned that it is the same weight or less than a old vw bug around 2000 lbs. He still said it was too heavy. He said this while I was looking at a Chevy Suburban sitting on the lift! LOL! the guy had no clue. I just left and went someplace else.
It seems when you find a good person that knows something they are never there long. Oh well, i guess that is why i do things myself most of the time.
Of couse the 2006 town and Country goes to the shop. Sideways V6 motors are a pain.
On another note, I am dealing with a Bad AC coil in my home and prices some people give me are all over the place. Makes me want to go to the local community college just to take HVAC repair so I can do it my self!:D
later
E
/ ym2000 not charging #13
Jerry
Looks like it works for ym1700 also looked on hoyes site same part number on both 1700 and 2000 went to get them of coarse they did not have them should be here monday only 61.00 alot better than 200.00 now i can fix the lights and work even later thanks for the info any other little tricks up your sleeve thanks Ed
/ ym2000 not charging #14
I installed the new parts today everything bolted and plugged up right and the best part it all worked thanks for the info on this site you guys have helped me alot thanks Ed
/ ym2000 not charging #15
Erick,
I'am in the A/C business. So, I kinda know what you are talking about. Some advise. If you are going for replacment. Replace the condenser ( out side unit ) as well & opt for a 410 A system. If you install a new A coil & your condenser goes in a few years you will have to buy a new inside coil again 1 that will match up to R410 specs. Production of R22 is comming to an end & the price for it is going through the roof. Most states just going to school to learn about A/C isn't enough. You have to be state certified & also certification to buy refrigerant
thanks for the advice Kenmac, my 8 year old coil died on my ac/gas pack split unit up stair in my house. The old unit is a 2 ton that really should have been a 2.5 ton and 10 sear. going with a 13 sear 2.5 heat pump and coil hooked up to my existing gas unit. dual fuel! I wish i could afford to go to geothermal but way to expensive now.
thanks and now back to regular programing.:rolleyes:
Erick
/ ym2000 not charging #17
I'am not talking about geo. system. Like I said. I'am in the bus. & it is to expensive for me to do it even at cost. Just make sure the installer installs a R410a refrigerant system in your house & not the old R-22 type system
PALLET OF AIR FILTERS AND HEAVYEQUIPMENT PARTS (A68842)
PALLET OF AIR...
x (A68191)
x (A68191)
2014 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
PORTA POTTY (A67714)
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65056)
2021 CATERPILLAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
