YM2000 Alternator testing
/ YM2000 Alternator testing #1
Mslater
Baton Rouge LA
YM2000
Ok, I set my meter on ac and test which outputs? Thanks!
/ YM2000 Alternator testing #2
You want DC, put leads across your battery terminals, looking for +14vdc+- at high idle.
I checked at the batt running at about 1500 rpm and get 12.3 volts. Now that I know its not charging how to I narrow it down? Whats the procedure to test the alternator seperately? Thanks alot for your help!
/ YM2000 Alternator testing #5
I'm not sure if your bridge rectifier is in the alternator or the regulator; however, you can unplug the regulator from the alternator and meter across the alternator post and look for +20+- volts on AC or DC scale. No voltage says bad alternator, +20+- says bad regulator, AC or DC reading gives the location of the rectifier, which changes voltage from AC to DC. It's usually a bad regulator.
Gotcha, I'll give it a shot tomorrow. Thanks again!
2018 Bobcat T590 (A64126)
2018 Bobcat T590...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
NEW HOLLAND 355 FEED MILL (A64277)
NEW HOLLAND 355...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
Deutz-Fahr 6140 (A64126)
Deutz-Fahr 6140...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
