ym2000 air filter
/ ym2000 air filter #11
Garyd,
That's what we all hope to buy, a tractor that is fairly described and is a good value for the price. I'm glad you found a good dealer.
My purchase was similar. The short term second owner I got mine from gave up renovating minor stuff before he accomplished very much, and sold it to me at a reasonable price. The only significant problem turned out to be very simple: very old fuel which caused hard starting. That had caused him to buy a new (expensive!) starter and he gave up at that point without determining the cause.
Soundguy,
The place I went for my 'original' restoration parts is also a container importer, and I encountered similar minor problems.
The importer had a nice looking 'reconditioned' YM2000 that was being stripped for parts after a warranty exchange. I'll give him major points for treating that customer very well.
I got a seat with nice upholstery off his YM2000, then discovered it wouldn't fit my tractor. It's mount had been cut off and moved 2 inches inward. I can't swap the seat cover because this seat is much smaller. I can't use this 'reconditioned' seat. I don't understand why reconditioning included butchering the mount.
The other thing I bought on that visit was a complete fuel filter assembly. (My tractor had been maintained with NAPA parts replacing Yanmar parts, and had an auto fuel filter in place of the Yanmar filter assembly.) The used Yanmar filter assembly off that YM2000 contained a filthy filter element. Not 'reconditioned' like the tractor's nice appearance suggested.
So I bought a genuine Yanmar filter element for it but discovered it wouldn't fit this assembly - the filter assembly from that YM2000 had a shorter filter bowl, one superceded years before the apparent year model of the tractor I saw it removed from.
The VN reconditioned tractors I have seen show the model number in a round medallion next to the radiator. According to my YM240 parts book the medallion was first used about 1981. But this first-series fuel filter bowl, and the right-side oil dipstick on that YM2000, indicated an engine from 1975 or before. I think the VN reconditioners have so many tractors to pull parts from that they take later sheet metal, with that medallion, and put it on tractors from all years. Buyer beware!
1danny,
re what parts do I need:
I want an authentic reupholstered seat, eventually.
Also I will eventually buy that longer second-series fuel filter bowl. That's the last part I need to install the genuine Yanmar filter assembly. For now I have two fresh non-stock filter assemblies installed in series so no hurry.
(That was a separate surprise - A brand new 'Yanmar fuel filter assembly' I bought on ebay from a large dealer was generic, and won't take Yanmar elements - or any element available from NAPA etc so far as I can determine. See the attached photo. Since I didn't know the quality of this generic filter, I added it in series with the automotive filter I had just replaced.)
I hope all this doesn't scare off a potential Yanmar buyer. None of this was serious or expensive. Most of the time I spent was trying to achieve perfect authenticity, rather than improve usefulness of the tractor.
Now that everything works smoothly, my resale value is considerably more than what I have into it. The tractor runs great, and I'm pleased!
/ ym2000 air filter #12
California.. I noticed similar things after I got looking. My two front wheels were the same size, etc.. but two different rims.. Also.. my fuel bowl was yanmar.. but was from a different model, as the oem yanmar 1700 filter I ordered didn't fit it either. I had to go match one up at napa.
Mine is an older late 70's green model... I've not seen one like it since.
Soundguy
/ ym2000 air filter #13
</font><font color="blue" class="small">( Mine is an older late 70's green model... I've not seen one like it since. )</font>
Soundguy,
There was a brochure on ebay that I think describes first-series YM195, the US version of your green YM1700.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3670639976
The auction ended with no bids so it may still be available.
/ ym2000 air filter #14
California, most parts for your YM240 are still available from Yanmar, I keep many of them in stock. The OEM fuel filter that came on your YM240 is 2 5/8" long. I also have the longer filters & bowl's if you want that. The air & oil filter's are still available too. We ship these parts every day.
Danny
Parker Equipment Co
/ ym2000 air filter #15
Danny, I have a new correct fuel filter element 104500-55710 still in Yanmar packaging.
It measures 2 5/8 as you noted. At the next filter maintenance I'll get an oem bowl so I can finally install this in place of the cobbled-together stuff I'm using now.
Thanks for your advice. I hope to do business with you some day.
/ ym2000 air filter #16
The closest match I have found for the YM2000 air filter is a Wix 46022. The filter is just a little too short. I compensated for this by adding a circular ring cut out from a sheet of rubber gasket material. It seems to work just fine. The rubber gasket material secures a tight fit on the filter.
/ ym2000 air filter #17
That sounds like how my air filter was done up on my 1700..
Soundguy
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2013 Freightliner M2 Bucket Truck (A60352)
2013 Freightliner...
2008 Nissan Rogue SUV (A59231)
2008 Nissan Rogue...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
