YM2000 200 PSI Compression No. 1 Piston
   / YM2000 200 PSI Compression No. 1 Piston #1
Foolster
I am trying to get a YM2000 running. It puffs white smoke. My local diesel shop did a compression test and reported the first piston as 200 PSI and the second as 400 PSI. I previously had them rebuild the injectors for me. The first injector showed no signs of having fired while the second clearly had carbon from firing. What should I do next? I would like to get the tractor running fairly inexpensively to see how useful it is. Eventually I would like to rebuild the engine. Does it make sense to only rebuild the first piston? If the rings are bad may I drop the oil pan, pull the rod bearing, pull the piston, clean it, check the piston and cylinder for damage, if none then put new rings on the piston, carefully replace the rod bearings the same way they came out, and have a repair that could last a few years?
A second thought. Has any one ever tried to upgrade a 2 cylinder Yanmar 2000 to a three cylinder engine?
   / YM2000 200 PSI Compression No. 1 Piston #4
The YM2001,2002,2010,2020 are 3 Cyl. 24Hp.
   / YM2000 200 PSI Compression No. 1 Piston #5
It might be cheaper to buy a different tractor than to upgrade the engine. Besides, I have heard that the 3 cylinder engines do not have as much low end torque as the 2 cylinder ones. They are supposedly quieter though.
   / YM2000 200 PSI Compression No. 1 Piston #6
Three cylinder is definitely way quieter than the two!!
Another bit of information. When I bought the tractor the ground around it was littered with empty starter fluid cans. However the price I paid was so low that any work I put into the engine to make it run will still make it a good deal.
   / YM2000 200 PSI Compression No. 1 Piston #8
You would spend $3000 turning your $3000 tractor into a $3000 tractor.
   / YM2000 200 PSI Compression No. 1 Piston #9
Hmmm? You might need new pistons.
   / YM2000 200 PSI Compression No. 1 Piston #10
And some head work?
Hopefully not like the other guy on here recently that needed a new oil pan as it blew it off useing starting fluid.
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
