YM1700 Hydraulic filter screen
/ YM1700 Hydraulic filter screen #1
Saggydog
Michigan
YM2020
Can anyone tell me where it is and how to remove it? After draining my fluid I unbolted a triangular plate at the front of the transmission (3 bolts). The plate had something attached to the back of it and would not easily pull out so I closed it up. Is there any other external stuff that I have to remove prior to trying to get this filter out? /forums/images/graemlins/confused.gif
Saggydog (Brian)
/ YM1700 Hydraulic filter screen #2
CAREFULLY, pullit straight out. It is fit to the inside of the opening and sealed with an 'O' ring part way in. the filter is attached to the inner face of it.
Richard.
Thanks Duck. I will try to pull it straight out. When I met resistance the first time I didn't know if it would take a little pressure or not.
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2020 CZ Engineering CZ15KP 26ft Pole Trailer (A59230)
2020 CZ...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2025 Hydraulic Skid Steer Auger Attachment with Bit (A59228)
2025 Hydraulic...
