YM165D Wiring Diagram Needed
/ YM165D Wiring Diagram Needed #1
gt14
Aumsville Oregon
Yanmar YM146 YM165D
I have a YM165D. I just got a new starter and it won't engage. If someone has a wiring diagram so I can check voltage to the starter I would appreciate it. Thanks Dan
/ YM165D Wiring Diagram Needed #2
Here is a copy of the electrical out of my book. If you cannot read this pm me your email and I will send it to you .
JDJ257
SEMPER FI
Thank you I will test the connections tonight. Could be my Clutch sensor not activating. Maybe I will just wire direct to test.
/ YM165D Wiring Diagram Needed #4
No problem let me know if you need any other pages out of my book :)
Do you have the service manual? My other tractor a YM146 has a trouble shooting guide in the service manual. It shows ohms and voltages for the wiring ect. So you can track down where the trouble is coming from. I could have a relay or a voltage regulator that is bad. Thanks Dan
Got the starter to work tonight. It was the flywheel housing. It was too rusty along with the mounting bolts for the starter. I sanded the area down and it fired up. Now a new problem no oil pressure and I can't get the dipstick out of the rear transmission case.
/ YM165D Wiring Diagram Needed #7
I checked my manual and I do not have the section you need. Sorry I am glad you figured out your problem. I to had an oil psi problem mine ended up being the regulator behind the filter as long as I took it apart and cleaned it I got psi. I ended up flushing the motor and so far no more problem. Good luck
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
