YM1500 hydraulic fluid change question
   / YM1500 hydraulic fluid change question #1
boonesmith
Pinehurst, TX
Yanmar 1500D
Does the "fluid return bolt" (banjo bolt) on the hydraulic return line thread into the cover over the strainer, or into an internal pipe? The banjo bolt on my YM1500 is really tight. I don't want to use an impact wrench on it if it is removed with the cover.
I cannot tell from the parts manual or service manual I have where the bolt is threaded.
   / YM1500 hydraulic fluid change question #2
The suction line fitting threads into the cover plate. You can just unhook the rubber coupler in the line & leave it attached if you can't get it off.
Good luck,
Aaron
Parts@HoyeTractor.com
(940)592-0181
Thanks, Aaron
I don't think that fitting has been taken loose since the factory installed it!
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53473)
2012 RAM 5500...
2024 CFMoto Cforce 600 4x4 ATV (A51694)
2024 CFMoto Cforce...
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
2024 40 ft. High Cube Shipping Container (A53117)
2024 40 ft. High...
