YM1500 hydraulic fluid change question
   / YM1500 hydraulic fluid change question #1
boonesmith
Pinehurst, TX
Yanmar 1500D
Does the "fluid return bolt" (banjo bolt) on the hydraulic return line thread into the cover over the strainer, or into an internal pipe? The banjo bolt on my YM1500 is really tight. I don't want to use an impact wrench on it if it is removed with the cover.
I cannot tell from the parts manual or service manual I have where the bolt is threaded.
   / YM1500 hydraulic fluid change question #2
The suction line fitting threads into the cover plate. You can just unhook the rubber coupler in the line & leave it attached if you can't get it off.
Good luck,
Aaron
Parts@HoyeTractor.com
(940)592-0181
Thanks, Aaron
I don't think that fitting has been taken loose since the factory installed it!
2020 RAM Promaster City Mini Van (A53117)
2020 RAM Promaster...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
