YM1500 hydraulic fluid change question
   / YM1500 hydraulic fluid change question #1
boonesmith
Pinehurst, TX
Yanmar 1500D
Does the "fluid return bolt" (banjo bolt) on the hydraulic return line thread into the cover over the strainer, or into an internal pipe? The banjo bolt on my YM1500 is really tight. I don't want to use an impact wrench on it if it is removed with the cover.
I cannot tell from the parts manual or service manual I have where the bolt is threaded.
   / YM1500 hydraulic fluid change question #2
The suction line fitting threads into the cover plate. You can just unhook the rubber coupler in the line & leave it attached if you can't get it off.
Good luck,
Aaron
Parts@HoyeTractor.com
(940)592-0181
Thanks, Aaron
I don't think that fitting has been taken loose since the factory installed it!
Killbros 260 Seed Conveyor (A53473)
Killbros 260 Seed...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
New Holland C238 (A50123)
New Holland C238...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A53426)
2013 FREIGHTLINER...
2017 Bobcat MT85 (A50123)
2017 Bobcat MT85...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
