YM146 Power shift
/ YM146 Power shift #11
kenmac said:
Check with tractor ernie . I think he posted that his tractors have atf in them
Ernie does use ATF, Mercon if memory serves me correctly. I recently asked Ernie but then didn't need to add any fluid so it isn't promanently stored in memory.
/ YM146 Power shift #12
I don't know how well transmission fluid works with the rearend gears ernie says they have had no problems . I think the power shift clutch pack is somewhat like transmission clutches in vehicles with auto. trans.
/ YM146 Power shift
Thanks for the replies! I am gonna try the Mercon ATF in it. I have also gone through the Power Shift control linkage and tightened up all the possible troublepoints. That has been a huge help already. I found lots of slop in the linkage and cleaned that up. Now when I find time I will do the fluid change to see what that does. I am glad that the fluid doesn't smell "burnt" so I doubt that I have any internal leakage issues.
2012 Honda Civic Sedan (A59231)
2012 Honda Civic...
CAT Chassis Only (A59076)
CAT Chassis Only...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
1993 Baja 29ft. Boat w Tri-Axle Boat Trailer. (A59231)
1993 Baja 29ft...
2004 Toyota Camry Sedan (A59231)
2004 Toyota Camry...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
