ym1401
/ ym1401 #11
California said:
Mike, what is the difference in size between 1401/1510? Is 1610 larger yet?
The 1510 and the 1401 are the same length, 84"--The 1510 is 1 inch wider at 39" and has bigger wheels (I believe). The 1510 is heavier by almost 200# at 1345 lbs. One interesting difference is that the wheel spacing is not adjustable on the 1510, but maybe that is associated with the Powershift too. I do not know.
The 1610 is heavier yet at 1600#, longer 103", and wider 44". The 1510 is the smallest popular powershift model. (There is a 1110, but it is not very popular).
Maybe that is more than you wanted to know.:D :D
The 1401 is a fine little tractor and will do a lot of work if you just take your time.
Mike
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
iDrive TDS-2010H...
2024 Case IH Farmall 75A (A60462)
2024 Case IH...
