ym1401 Idiot lights.
/ ym1401 Idiot lights. #1
MarkStewart
Pine Bush NY
Yanmar 1401
I wanted to know if the oil pressure and temp lights were supposed to come on briefly when I first turn on the ignition key? I've never seen the lights come on my 1401. Thanks.
/ ym1401 Idiot lights. #2
<font color="blue">...if the oil pressure and temp lights were supposed to come on briefly when I first turn on the ignition key?... </font>
In most cases, the "warning" lamps will light up briefly when starting to let the operator know they are "working" and not burned out...
Same thing with your automobile...
/ ym1401 Idiot lights. #3
Check all fuses in the fuse panel and connections to the temp and oil pressure sending units. Oil sending unit is under alternator. Temp unit is on top of block near top hose. Wiggle connections to make sure they are tight. Also, you can check the bulbs in the dash by removing front dash panel and reaching up inside to remove them.
Jim
/ ym1401 Idiot lights. #4
You can also turn the key on and pull the terminal loose from the sending unit and short it to ground. The light should come on bright.
/ ym1401 Idiot lights. #5
I own a 1401 which is very similiar to the 169 American version. The owners manual states that the temp light will not come on when starting or the switch is on. The oil light will come on if the switch is turned on or when starting the tractor. The oil light should go off within seconds after the tractor starts. The temp light will only come on if the engine over heats. The manual suggests switching the oil and temp bulbs since they are the same and if the switched buld works with the oil sensor you can be assured that the bulb is ok. I do this on a yearly basis. /forums/images/graemlins/smirk.gif
/ ym1401 Idiot lights. #6
Professor- that is good to know. I wondered why my 1401D's temp light never came on. I never worried about it much. When I'm working it hard, I pay a little extra attention to sights, smells and sounds that the tractor makes. When I start it cold, I crank it with the compression release pulled until the oil light goes out.
(1) UNUSED 26X12.00-16 TIRE W/ 5 LUG RIM (A64280)
(1) UNUSED...
100" Bucket (A64119)
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
Lilliston 4 Row Rolling Cultivator (A64119)
Lilliston 4 Row...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
