ym1300d 4 wheel drive
/ ym1300d 4 wheel drive #1
greyghost
need help in finding some one to fix both right and left drive hubs.
/ ym1300d 4 wheel drive #3
We have been collecting lists of mechanics and shops around the country for the last few years that are happy to work on Yanmar tractors. We have launched a new "finder service" free of charge on our new website. Might be worth a shot.
www.YanmarOwners.com
Aaron
parts@HoyeTractor.com
(940)438-0386
I live in Harriman, Tn. I have a 1994 yanmar 1300d. I had the place where i bought the tractor to order me everything i need to fix both hubs, which he did (supposedly). The book he had was in Japanese so he really did not know. I have two stripped gears in the hubs. I was looking for someone who knew where to get the right parts and put it together the way it is supposed to be. Any help would be appreciated.
/ ym1300d 4 wheel drive #5
Sorry to break this to you, but your parts isn't the only thing your seller is ignorant (or worse) about. YM1300 goes back to the 1970s, and guessing (as I'm not in the office) I'd say 75-78 or 79. The gears in those front hubs are most likely available only as salvage, and I'd be surprised to find them considering how many requests we see for the same parts. If the place where you bought it can order the parts, any mechanic can fix it; however, I'd be right curious as to where they will order the parts (other than salvage), 'cause I don't know where to get those parts new. Posters here may have suggestions for you to check for salvage. Start with Fredricks 256-773-9951 then check Hoye 940-438-0386 Sounds like best bet may be to try to get your money back and buy another model more easily maintained.
/ ym1300d 4 wheel drive #6
I agree with LMTC. My records show that Yanmar stopped making the 1300D in 1980.
/ ym1300d 4 wheel drive #7
</font><font color="blue" class="small">( try to get your money back and buy another model more easily maintained. )</font>
What's the earliest, or least expensive, of the small gray market Yanmar 4x4's that has decent parts support. 1400D? 1401D?
Also is 1500D too old to have front axle parts available?
Someday I may trade down to whatever has FWD and can run a 48" rotary mower as its heaviest task. Any suggestions?
/ ym1300d 4 wheel drive #8
Wayne at LMTC always seems to have a YM1401D on his website /forums/images/graemlins/grin.gif
So, in my mind, that may be a good model. He services what he sells and probably won't sell something that has no/little parts availability. /forums/images/graemlins/laugh.gif
/ ym1300d 4 wheel drive #9
I always have at least one 1401d, too.
Parts are no problem so far. My importer probably gets half a container of 1401d's each time he gets a load. He fills the rest with other models.
/ ym1300d 4 wheel drive #10
California,
The 1500 &1500D have some of the best parts support I think. There are several aftermarket companies that reproduce all or most of the front end parts now. In a month or so, we should have all of the rebuild parts for the 1500D front ends in stock. Much beter than the 1300D/1100D.
Aaron
Parts@HoyeTractor.com
(940)438-0386
/ ym1300d 4 wheel drive #11
I should have the parts to repair your YM1300D. I'm about 200 miles away, 45mi south of Birmingham. We just rebuilt a YM1300D front drive last week.
Danny
/ ym1300d 4 wheel drive #13
I'm in the same boat, with a 1300D left front hub set of gears completely messed up.
Local suppliers can't assist and from posts here I gather these can be/are hard to find.
I'm wondering if anyone can access the following new/used:
1300D w/square headlights and need 3 gears in the left front hub assembly.
1-small gear on end of axle shaft from Dif.
2-double faced gear in hub assembly.
3-larger gear in hub assembly that provides final drive to wheel.
Thanks.
Nick (tabmow222)
2021 Tesla Model Y Long Range AWD Sedan (A61574)
2021 Tesla Model Y...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2022 Ford F-150...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
