YM1300 Oil Pressure
   / YM1300 Oil Pressure #1
DarinM
Texas
Yanmar YM1300
I just finished installing the sun pro 1 1/2" gauge kit and now I'm wondering about the operating oil pressure. Can anyone tell me what I should be expecting? When the engine is first started I'm running around 24-26psi, but after it is up to running temperature and at running speed for mowing, it drops to around 18psi? I am running full synthetic shell Rotella 5w40 oil. Should I be running a non multi weight? Is there something else going on ? or what?..... Any thoughts would be appreciated.
   / YM1300 Oil Pressure #2
I would go to a Rotella 15W-40 or heavier.
   / YM1300 Oil Pressure #3
18 psi should be more than sufficient oil pressure. Normally, oil pressure will drop much lower at idle when the engine is hot. For reference, I think the oil pressure switch is supposed to turn the light on under 3 psi.
However, I have to agree with the above post - get to WalMart and buy some Shell Rotella T 15W40. You need to be running an oil made specifically for diesel applications.
Thanks for the replies... While the Oil I'm using did state it was for Diesel engines, I was not too sure about the weight. I will stop today and buy a heavier oil.
Again, thanks for the replies.
   / YM1300 Oil Pressure #5
Ha! that's nothing. You 'new' tractor owners are spoinled.
Collect some real old iron from the 30's and 40's and 50's...
I have a 46 2N that starts with 18 psi COLD.. and then drops to 10 hot idle..
I know people that have N's that start cold with 10 and have 5 or so showing on the gauge.. and have been that way for 10 years... /forums/images/graemlins/wink.gif
Soundguy
   / YM1300 Oil Pressure #6
Funny thing about oil pressure, if it is truly low and not just a faulty gauge, the "fix" is normally a complete overhaul, (all new bearings), as opposed to a new oil pump.
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2017 CATERPILLAR 420F2 BACKHOE (A59823)
2017 CATERPILLAR...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
