YM 2310d generator to alternator conversion?
/ YM 2310d generator to alternator conversion? #1
JL Sargent
Has anybody done this? I have a YM 2310D with the standard dynamo/regulator setup that has gone kaput. I'm interested in going to a 1 wire GM alternator. Anybody here done this?
/ YM 2310d generator to alternator conversion? #2
There are several who have changed the dynamo to an alternator if you search the forum you will find others like this or this. This seems to be a rather popular "upgrade" as the regulators are kind of pricey.
Mike
/ YM 2310d generator to alternator conversion? #3
Well, went back and reread my directions and explanation and was surprised at my details. I did not respond earlier, because my advanced aged brain could not remember the details.
For what it's worth from what I can remember the changeover is really quite simple if you have the alternator sitting there. I think the basic difference lies in whether you care that it may not look quite original or whether you have the space under the hood.
/ YM 2310d generator to alternator conversion? #4
Another possibility to explore - Yanmars a little older than yours used the same Hitachi charging gear that Hitachi also sold to Nissan during the same years. You might find that Autozone has your alternator for $29.95 (rebuilt) except cataloged as a Datsun/Nissan part from your tractor's year.
The way to verify this is take in your regulator and see if it looks like Autozone's. My regulator tested identical on Autozone's test equipment, same plug and everything, so I bought the corresponding Nissan/Hitachi 35 amp alternator to replace my dead 15 amp original Yanmar/Hitachi one. It was a perfect fit.
Hey California, I know what some of these tractors actually came with an alternator originally. Mine however is a dynamo connected to a voltage regulator which also has a small box connected to it. I'm looking to leave all that behind for a single new GM alternator. It sounds like you were able to replace just the voltage regulator on your tractor and get back to work, right?
/ YM 2310d generator to alternator conversion? #7
Yours has the little pancake alternator? I don't know the solution for that one.
Sad story - the space under the mechanical regulator on my YM240 was packed solid with hardened mud when I bought it, apparently a mud-dauber encampment. So I hit it with the pressure washer as part of my initial 'renovation'. Big mistake. That model regulator had big high-current resistors under there, mounted external for cooling, that my cleaning shorted out. They soon went up in smoke then the alternator soon followed.
I bought a new $70 regulator from a participant here then on a hunch took it to Autozone. It tested perfect when described as '72 Datsun - plug and all. So I bought that model alternator from them. My source for the regulator has always provided excellent service so I didn't send it back for refund, but I noted that Autozone's version of the same part was $19.
I had hoped a conversion like this would work for you, but it sounds like you don't have space for an ordinary automotive alternator.
I've ordered the 1 wire alternator that I linked to above. I will post the results when I get the conversion done.
/ YM 2310d generator to alternator conversion? #9
I did this on my 2301D awhile back. I used the Denso alternator but had to build an idler pulley and bracket to get by the radiator hose problem. It was pretty simple and works great. I may have some pictures if you care about looking.
Hey Choffman, I would appreciate seeing any pictures on the project you care to share!
Thanks.
/ YM 2310d generator to alternator conversion? #11
Unfortunately, the tractor is not here right now, but here are a few pics I took when I did it..
http://home.comcast.net/~choffman41/yan1.jpg 1. Started with an old Chevy A/C bracket.
http://home.comcast.net/~choffman41/yan2.jpg 2. Cut the pulley off and tapped it from the back to mount it.
http://home.comcast.net/~choffman41/yan3.jpg 3. You can barely see the idler below the alt. I used the original Yanmar bracket.
http://home.comcast.net/~choffman41/yan4.jpg 4. View from top right.
http://home.comcast.net/~choffman41/yan5.jpg 5. View from rear.
http://home.comcast.net/~choffman41/yan6.jpg 6. View from left.
I made a nice spacer to replace the rusty nut that is between the alt and adjusting arm. Also, I ran a piece of flat bar from that point to the firewall for better support as it was a little floppy due to engine vibration. It's been working great for 2 years. Also put a voltmeter on the tractor. When first starting, the engine has to rev to about 2000 to excite the alt, then it charges fine at any rpm.
Thanks for those photos and description Choffman. Mine is very similar. I have made up the top and bottom brackets and mounted the alternator. I believe I have cleared the bottom hose by mounting the alternator a little farther away from the engine. I test fitted the side cover and see that it will require spacers of about 1/2" to reinstall with my present setup. I'll post some pictures of my setup too for anybody interested. If this doesn't work out with relation to the hose I guess I'll be looking for that idler pulley.
Ok, got it done. I'm real happy with the way it worked out. I have about 1/4" clearance between belt and the bottom radiator hose which I slid a "guard" over. Also the alternator is about 1/16" from the side cover without any mods to it.
Just wanted to followup on this. We have been planting pumpkins this weekend and ran the tractor quite a bit. Alternator working out great so far. Tractor cranking much quicker after this conversion. No telling how long the old setup has been dying. This is certainly a recommended upgrade.
Thanks for all the help guys. Suggestions and pictures on this thread as well as other threads linked to much appreciated. :thumbsup:
/ YM 2310d generator to alternator conversion? #15
JL,
Nice work. How did you wire it all up, since its now one wire.
I'm thinking about the same thing, my 226 has that same hose in the
way as yours did. Nice work around.
Wiring it up was the easy part. Since its a 1 wire alternator, all you have to do is wire the "1 wire" to the battery hot and your in business. I did nothing else to mine. I thought at first my alternator light would come on, but that hasn't been the case.
Its been 6 weeks since I did the conversion and all is well. We have planted a small pumpkin patch and also we have run the finish mower and bush hog probably 10 hrs or so. The one change I have made since that picture was with the small sleeve you can see on the lower hose. I swapped in a stainless sleeve for the black nylon one you can see in the photo for extra protection. The belt occasionally does kiss that area and the nylon was starting to cut. Now the stainless takes those little pecks with no problem.
I've been real happy with the little alternator. It's seems much more powerful than the previous generator type setup. Battery seems hotter all the time and the starter works first time every time since the conversion. Before it was a 50/50 whether or not it was gonna spin on first try.
/ YM 2310d generator to alternator conversion? #17
Sargent: Not to highjack the thread, but I noticed you have a Fram filter in that engine.
I used to hang out on some performance motorcycle forums and there were a lot of race engine builders there. There was a lot of filter testing and dissecting of filters (among other things) and the general consensus was that no one would run a Fram. Their construction techniques are inferior and they are prone to failure. When they "fail" the oil still flows, but it is not filtered.
.02 cents that was not asked for... I hate seeing Fram filters on engines tho.
/ YM 2310d generator to alternator conversion? #18
Noooo , not another Fram sucks and i would not run it thread!
I usually run whatever is cheapest! I've never had any problem with any filter and I have put a couple of million miles on vehicles! I just think changing your oil and filter sooooo much more important than what brand you use.:thumbsup:
Now, lets get back to Gen/Alt conversions on Yanmar tractors.:licking:
/ YM 2310d generator to alternator conversion? #20
I'm interested in this conversion. My alt. is toast.
Has anyone found a on-the-shelf mounting kit that would work instead of fabbing up our own mounts?
