ym 2000 smell
/ ym 2000 smell #1
lancem
Martin,Ga
YM2000
I have A ym2000. After it runs for about 15 min, I can smell transmission fluid( I think). I can not find A leak and It does not seem to using any extra. Any ideas?
/ ym 2000 smell #2
If the transmission works fine, maybe check the brakes holding and generating some heat and associated smells. I had a 1610 D Yanmar that was bad about that and also the drive clutch sticking, if not used often. Ken Sweet
/ ym 2000 smell #3
Wouldn't be antifreeze your smelling would it?
/ ym 2000 smell #4
Im not trying to be a smart A so bear with me. There should be no transmission fluid (as labled on bottle) in that tractor. I know you said "think" but if your correct and know what hot or burning tranny fluid smells like you might want to chech what your fluids are. The transmission/hydraulics are (by the book) supposed to br unversal tractor transmission/hydraulic fluid of JD 303 spec.
Now thinking about it tractor ernie and others use Transmission fluid in their tractors with no problem, but i think they mostly use it in the powershift ones for cold operation. Not saying in a gear one you could not use it with out trouble though.
But your only fluid in that tractor is what ever is in the transmission resivoir, engine oil 15w-40, and radiator fluid, and deisel fuel, so it has to be one of those getting hot and leaking or burning on the exhaust or in combustion chamber.
/ ym 2000 smell #5
Is there any way the hydraulic system could be operating under constant load, heating the fluid? The lift handle is pulled full back to raise then forward a little to hold. It might be straining if the lever is stuck all the way back.
And ... I once poured the remainder of a jug of UTF (JD303) into my fuel tank so I could re-use its container for something else. It was maybe a pint of clean UTF mixed into five gallons of diesel. It ran fine.
But for months the tractor smelled just like the gear oil smell from my old 4 speed Wagoneer when it was run hard in 4wd, playing Rally on fire roads, which smelled hot everywhere underneath and left its transmission seals sweating.
I had to keep reminding myself that this time the hot-transmission smell was from the Yanmar's exhaust as it consumed that ersatz fuel, not from its transmission.
/ ym 2000 smell #6
Does the transmission case feel hot to the touch after running it for a while? Ken Sweet
/ ym 2000 smell
I have only had the tractor for about twenty hours, so I really don't know what kind of fluid the pre owner had in it. Maybe i just need to drain all of the fluids
and start over with fresh. The trans is warm to the touch but i would not call it hot. Thanks for everyones help.
/ ym 2000 smell #8
My tranny will get hot after an hour or two, but you can still hold your hand on it. Yep , you got it changing fluids is the best bet for a new to you tractor. Piece of mind that you know its the right stuff, plus it gives you a base line for future change times.
/ ym 2000 smell #9
Did the previous owner paint the engine or muffler right before you bought it?
Sometimes paint will let off a smell when it gets hot.
/ ym 2000 smell #10
If the tranny fluid is still red, I wouldn't worry about it unless you have hydraulic problems. As Ken said, make sure the brakes are not locking up. I would remove the drain plugs from the brake housings and the bellhousing and see if any fluid comes out, and make sure the servicing stop valve is not partly closed.
