YM 2000 - Roll Over
   / YM 2000 - Roll Over #1
sls
Mississippi
YM 2000
A friend and I purchased YM2000s and think they are great. Last week he rolled his, and how he did it is a little scary. Was cleaning up storm damage with a box blade and a log turned. One of the back tires went up on the log. BAM!! The tractor rolled over. He wasn't hurt but a little scared.
As everyone knows, there's not much of a wheel base on these tractors so be carefull.
   / YM 2000 - Roll Over #2
If you haven't already done so, you need to reverse your rear wheels, (move side to side), to gain a little wider stance and still keep the wheels pointed in the right direction.
   / YM 2000 - Roll Over #3
Glad he is okay. I turned and swapped around my tires and filled them on my 1700 and it makes big difference. I sometimes get nervous using the box blade with a good load in it. I always keep my clutch foot ready. I have had the front wheels off the ground just a little a couple of times and it was scary. I also take it real slow when dragging stuff like that.
I never realized how dangerous tractor can be till I got one. I have had mine for about a year now and still feel like a newbie.
   / YM 2000 - Roll Over #5
If you are going to put water in your tires stay below the center .If you fill the tires all the way to the top then it gets top heavy .
   / YM 2000 - Roll Over #6
</font><font color="blue" class="small">( If you are going to put water in your tires stay below the center .If you fill the tires all the way to the top then it gets top heavy . )</font>
The above is just plain wrong. See links below.
Gemplers
Firestone
LSU Ag Page
   / YM 2000 - Roll Over #7
If you live in level ground do what you want .But it you live in the hills as I do stay below the center of the wheel .I don't care what Firestone or any one else says 44 wide to a 48 wide with the water all the way to the top will get top heavy do the math will a level and you will see, been there done that I know .
   / YM 2000 - Roll Over #8
The best thing that you can do for stability is put the rear wheels at the widest point and fill the tires to ABOVE the rim and / or put on wheel weights. You will be totally amazed at the difference that it will make.
   / YM 2000 - Roll Over #9
OK, I concede.
It was time for me to leave anyway.
   / YM 2000 - Roll Over #10
LMTC.. don't feel bad... As many years as i have been around tractors.. I have never seen it advised to fill tires to LESS than 'above' the rim'.
Gizmo can do what he wants with his own tractor.
Soundguy
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
2001 Ford Ranger Pickup Truck (A51692)
2001 Ford Ranger...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
2018 Mitsubishi Eclipse Cross SUV (A53117)
2018 Mitsubishi...
