YM 2000 over running clutch
/ YM 2000 over running clutch #1
JRB
East Tennessee
Yanmar YM2000
I plan to start using a rough cutter (brush cutter) with my YM 2000 tractor and would like to know if an over running clutch is needed. I have used a finish mower for about (2) seasons and never felt it pushing the tractor when I push the clutch in. Does the rough cutter react different?
Thanks for any replys.
JRB
/ YM 2000 over running clutch #3
I'm pretty inexperienced with tractors and I run an over-running clutch on mine. Guys with much more experience than I've got all say they wouldn't think of running without one. I think there's a lot more energy stored in the rotating disk of a brush hog than in the rotating blades of a finish mower.
Guys, is that right?
/ YM 2000 over running clutch #4
The 2 long rough cut blades have a lot more momentum than the finish mower 3 short blades. Use an over running clutch.
/ YM 2000 over running clutch #5
I agree, picture a large truck (18 Wheeler) going 40 mph and trying to stop vs a car.(just to give you some idea.)You should be able to pick up a over run cluch for 40.00-50.00.
/ YM 2000 over running clutch #6
JRB,
The enregy W stocked in a rotating blade is in proportion of the square of its lenght L let's speake W=a*L*L.
It means that if you multiply the lenght of a blade by :
A factor 2 the energy stocked will be multiplied by a factor 4
A factor 3 the energy stocked will be multiplied by a factor 9
A factor 4 the energy stocked will be multiplied by a factor 16
So I confirm that you must use an over-running clutch.
Phil
Thanks for all of your replys. I will get one soon.
JRB
/ YM 2000 over running clutch #8
Not only the baldes.. but many rough cuttters use a stump jumper as a blade carrier. That's a pretty big flywheel.. figure the blades too, and that's alotta stored energy!
Soundguy
Where is the best place to buy the quick release over running cluch and what is a fair price for one?
JRB
/ YM 2000 over running clutch #10
Any place that sells tractor supplies should have them, or you can order one here.
/ YM 2000 over running clutch #11
Be prepaired to pay 25-50$ for a pin on one.. and 50$ to 80$ for a quick release. cheaper quick release will be a thumb button.. higher price ones will be a sliding collar.. etc..
Tsc sells them..
Soundguy
Wooden Cowboy Statue (A64127)
Wooden Cowboy...
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
3 Point Bale Mover (A65640)
3 Point Bale Mover...
John Deere 6400 (A64126)
John Deere 6400...
Frontier BB5048L (A64126)
Frontier BB5048L...
