YM 2000 over running clutch
/ YM 2000 over running clutch #1
JRB
East Tennessee
Yanmar YM2000
I plan to start using a rough cutter (brush cutter) with my YM 2000 tractor and would like to know if an over running clutch is needed. I have used a finish mower for about (2) seasons and never felt it pushing the tractor when I push the clutch in. Does the rough cutter react different?
Thanks for any replys.
JRB
/ YM 2000 over running clutch #3
I'm pretty inexperienced with tractors and I run an over-running clutch on mine. Guys with much more experience than I've got all say they wouldn't think of running without one. I think there's a lot more energy stored in the rotating disk of a brush hog than in the rotating blades of a finish mower.
Guys, is that right?
/ YM 2000 over running clutch #4
The 2 long rough cut blades have a lot more momentum than the finish mower 3 short blades. Use an over running clutch.
/ YM 2000 over running clutch #5
I agree, picture a large truck (18 Wheeler) going 40 mph and trying to stop vs a car.(just to give you some idea.)You should be able to pick up a over run cluch for 40.00-50.00.
/ YM 2000 over running clutch #6
JRB,
The enregy W stocked in a rotating blade is in proportion of the square of its lenght L let's speake W=a*L*L.
It means that if you multiply the lenght of a blade by :
A factor 2 the energy stocked will be multiplied by a factor 4
A factor 3 the energy stocked will be multiplied by a factor 9
A factor 4 the energy stocked will be multiplied by a factor 16
So I confirm that you must use an over-running clutch.
Phil
Thanks for all of your replys. I will get one soon.
JRB
/ YM 2000 over running clutch #8
Not only the baldes.. but many rough cuttters use a stump jumper as a blade carrier. That's a pretty big flywheel.. figure the blades too, and that's alotta stored energy!
Soundguy
Where is the best place to buy the quick release over running cluch and what is a fair price for one?
JRB
/ YM 2000 over running clutch #10
Any place that sells tractor supplies should have them, or you can order one here.
/ YM 2000 over running clutch #11
Be prepaired to pay 25-50$ for a pin on one.. and 50$ to 80$ for a quick release. cheaper quick release will be a thumb button.. higher price ones will be a sliding collar.. etc..
Tsc sells them..
Soundguy
New/Unused Landhonor 20,000lb Electric Winch (A61166)
New/Unused...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2015 BOBCAT T590 SKID STEER (A62129)
2015 BOBCAT T590...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
