ym 2000 4x4 front seals
/ ym 2000 4x4 front seals #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
need to do the front axle seal on my 2000, did the rear 2wks ago, piece of cake once I got the hubs off. any info would be apprciated.
thanks
Mark
/ ym 2000 4x4 front seals #2
If you did the rears already - the front will be no problem. You can see how they come apart here-->
4WD_EXTERNAL: Yanmar Tractor Parts
Just remove the wheel and the 4 bolts (#52) that hold on the steering arm and the box halves will seperate. This will let you move the project to a workbench. From there you can replace the knuckle seal (#31). To replace the axle seal you remove the plate (#31), the axle nut, and then pull out the axle. Then you can replace the axle seal (#34).
Aaron
Parts@HoyeTractor.com
(940)592-0181
OH, now I get it. I was looking at the picture but couldn't quite make it work.
thanks for the explination. I'll give you a call this afternoon after my 4 hour dentist appointment (ouch).
thanks
Mark
