YM 186D budget replacement rear wheels.
/ YM 186D budget replacement rear wheels. #1
suburban99
My 186D will need new rear wheel as the calcium has destroyed them. Not leaking yet but it's a matter of time.
Has anyone found a budget replacement? My brothers kubota has dodge dakota wheels on it I think.
The yanmar bolt pattern is 6 on 4.75 if memory serves...16 inch 8 inches wide. Tires are 9.5-16
/ YM 186D budget replacement rear wheels. #2
You need a ratio MATCH for your machine as it's 4WD. Some of the Yanmar made John Deere 50/55/70/90 series machines could be a perfect fit. You got to look around or find some data chart to reference.
Going forwards, its either beet juice or the PINK RV/Marine winterizing antifreeze pet safe coolant. The coolant is ideal as it's made from propylene glycol, a protectant and lubricant. It will even work to seal off rim to tire leaks. This stuff is in gummy bears, salad dressings, BBQ sauces, etc.
