YM 1700 sleeves
/ YM 1700 sleeves #11
I don't have my manual handy, but I strongly suspect the difference in bore size will go totally unnoticed except with a micrometer. No different than boring a car engine to clean it up.
/ YM 1700 sleeves #12
I was beginning to think that.. especially if the block is the same size. Add to that... if the block is the same.. that means the 1700 sleeves have a thicker wall than the 2000 sleeves... I think I would rather have the thicker walls....any comments?
Chris / Soundguy
/ YM 1700 sleeves #14
That's a bigger difference than I would have thought, however it should work.
Kryp, I hope you have done enough troubleshooting to convince yourself this is the problem, as it will be an expensive repair if wrong. I looked back to your original posts on Yahoo and you mentioned water squirting up thru head but couldn't tell from where. (valve guides?) I would check that block really close for cracks and if sleeves are leaking there will probably be corrosion.
/ YM 1700 sleeves
I am not sure what my next step will be on this one, I wanted to get the head pressure tested but it seems no one here does it. I had the head magafluxed and shaved but a pressure test would tell all on the head, looks like I may have to ship the head off for that or make a plate to bolt on it and do it myself and then use the plate on the block but I am not sure if standard water pressure will be enough of a test. I can also drop the pan yank out the sleeves and change the just the o-rings for a cost of about $50.00 in parts and thats the game plan I have so far.
/ YM 1700 sleeves #16
Sounds like some good ideas. If you can make a plate to bolt over the block, you could use a radiator pressure tester, I don't think too expensive, to test the block. Don't know how you could pressurize the head. If you get a leak then pull the sleeves and inspect everything carefully with a good light and a big magnifying glass.
/ YM 1700 sleeves
To test the head I would bolt the head and plate together with a gasket, seal front water pully housing and use the upper radiator outlet to test with. Radiator pressure tester(Hum) sounds good to me and that will be my next step unless I am missing something about the head your talking about. I know I can not see to much topside on the head but it should let me know on a crack.
thanks
/ YM 1700 sleeves #18
Kerry,
We can check and/or repair the head if you have no one else near you. One year warranty on the head.
Thanks,
Bruce
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2015 Kia Sedona Van (A61569)
2015 Kia Sedona...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
Iranch IRMC High End Massage Chair (A60463)
Iranch IRMC High...
AGT Industrial M-DGR (A60463)
AGT Industrial...
2016 Toyota Camry Passenger Car, VIN # 4T1BF1FK4GU249258 (A61569)
2016 Toyota Camry...
